@jekalmin
Thank you for your great plugin.
In my opinion, this is a new era in HA
I noticed that he has a problem with calling for inspection or action in a certain area, that is, if I tell him to check a specific device, he is accurate in reading the situation and acting on it, but when I tell him to check what is happening in a specific area, he is not accurate at all,
Would love your help
I also need a help in improving accuracy.
What I can currently think of is following:
Short term
- Adjust
temperature
ortopP
in options - Tweak prompt (current prompt is not ideal)
Long term
- Fine-tune model (I havenât tried)
Iâm also looking forward making response more accurate and consistent.
Please create a pull request if anyone has better prompt or functions.
A working function to get the real weather forecast of a city/region.
This one uses https://www.tomorrow.io/, which gives a detailed forcecast up to 7 days. You have to register there, but it is free with a rate limit for the api requests. But 500 per day, 25 per hour is ok, i think.
Replace <Your location>
with your city and the <Your Tomorrow.io key>
with your Api- Key.
- spec:
description: Get weatherforcast for a city specified by the user. Use "<Your Location>" if no city is provided.
parameters:
type: object
properties:
city_id:
type: string
description: City of the weather forecast.
required:
- city_id
function:
type: rest
resource_template: "https://api.tomorrow.io/v4/weather/forecast?location={{city_id}}×teps=1d&apikey=<Your Tomorrow.io key>"
value_template: '{{value_json }}'
EDIT: There was a mistake, i used resource instead of resource_template.
Hello everyone,
Iâm dealing with a issue and would appreciate your help. I have a whatsapp bot configured in the following way:
- name: WhatsApp
platform: rest
resource: https://api.callmebot.com/whatsapp.php
source: HA
phone: *****
apikey: *****
The code for the message-sending function looks like this:
- spec:
description: Use this function to send a message to WhatsApp.
parameters:
type: object
properties:
message:
type: string
description: Message you want to send
required:
- message
function:
type: script
sequence:
- service: notify.WhatsApp
message: â{{ message }}â
It works well
However, when I try to add a personal recipient by adding another configuration line like this:
- name: WhatsApp
platform: rest
source: HA
phone: *****
apikey: *****
I donât get the option to send a message at all.
Iâve tried several versions of code, for example:
- Version with two parameters - message and recipient:
- spec:
parameters:
type: object
properties:
message:
type: string
recipient:
type: string
description: Recipientâs name
required:
- message
- recipient
function:
type: script
sequence:
recipient: â{{ recipient }}â
- Version with two separate scripts - each script for a different recipient:
spec:
description: Use this function to send a message to WhatsApp to Merav.
parameters:
type: object
properties:
message:
type: string
required:
- message
function:
type: script
sequence:
spec:
description: Use this function to send a message to WhatsApp to Nehoray.
parameters:
type: object
properties:
message:
type: string
required:
- message
function:
type: script
sequence:
Unfortunately, none of these attempts have been successful. Does anyone have an idea or recommendation on how to add another recipient?
Thanks a lot to anyone who can help!
If anyone is interested, I had a great need for a timer as we use one almost daily and has performed flawlessly for weeksâŚ
## Use to set timer in HA using voice assistant
## along with automation located in automations.yaml#L42-L85
- spec:
description: Use this function to set timer duration.
parameters:
type: object
properties:
timer_minutes:
type: number
description: The timer duration minutes in '%H:%M:%S' format
timer_seconds:
type: number
description: The timer duration seconds in '%H:%M:%S' format
required:
- timer_minutes
- timer_seconds
function:
type: script
sequence:
- service: input_number.set_value
entity_id: input_number.timer_minutes
value: "{{ timer_minutes }}"
entity_id: input_number.timer_seconds
value: "{{ timer_seconds }}"
link to: automation for timer works with any combination of hours, minutes or seconds.
Thank you @jekalmin for your amazing work!!! Will your integration work with gpt-4?
I donât use that service, but here is how I added multiple recipients:
Multiple user notifications
Works perfectly, thank you very much.
Hi! Thank you for this. I got this working with gpt-4-1106-preview, but as soon as I changed back to gpt-3.5-turbo-1106 (way cheaper) I got this error message:
Should it work with gpt-3.5-turbo-1106?
Hello!
weird, I havenât tested it for a while but I have the impression that openai no longer wants to do anything on my equipment, for example turning on the lights:
it says ok but nothing happened
But read a sensor, itâs workingâŚ
There is no error in log
EDIT:
I found it! Maybe it can help someone:
In the conversation agent properties, âMaximum function calls per conversationâ was set to 0 ⌠!!
Hi @Dino-Tech,
in your automation, you use a service called âtimer.set_durationâ but it doesnât exists for me. I miss somehing
Many apologies, I use the Spook integration that provides that service. I have been using it since it was released and forgot that was exclusive to that integration. Spook - Not your homie
ok no problem
I love this integration. One thing I was struggling with is having the AI start/run my scripts. I get errors that it canât find the script name. Will I need to add in a spec and define each script?
It is normally not necessary unless you want to use such scripts with a specific template/variable.
For simple script.turn_on services you should ensure that either the script entity name, or friendly name, or alias matches your request to gpt (or at least is understandable by gpt).
Trial and error is your friend here.
Also, if you are using voice, double check the speech to text output to make sure it got your query right.
I have several weather entities exposed that I use for different needs. Iâve been having issues with retrieving accurate and consistent weather queries and after many different attempts, I ended up with this:
- spec:
description: Get the current weather
parameters:
type: object
properties:
type: string
description: Infer this from home location, (e.g. San Francisco, CA)
format:
enum:
- current forecast
- hourly forecast
description: The type of weather forecast information to search for and use.
entity_id:
type: string
description: entity_id
required:
- location
- format
- entity_id
function:
type: template
value_template: "{{states[entity_id]}}"
If anyone has any cleaner suggestions, please fell free to ping me, but this seems to have solved my issues so far.
Hi guys,
I just wanted to ask, everything is working pretty good for me, the lights, the sensors, the air conditioner, everything except the windows. Most of the time I get the following error:
Something went wrong: Service cover.open not found.
And sometimes it opens. Does anyone know how I can fix this?
Thank you very much
Since execute_service
function requires one of entity_id
, area_id
, or device_id
, you canât call script that doesnât require it.
If you want to call script that doesnât require entity_id
, you may try something like this.
- spec:
description: Run script of Home Assistant
parameters:
type: object
properties:
service:
type: string
description: The service
enum:
- script.livingroom_light_on
- script.livingroom_light_off
required:
- service
function:
type: script
sequence:
- service: "{{service}}"
However, if script requires any arguments, LLM doesnât know what arguments are needed for each script.
Try add following in prompt.
If service cover.open is to be used, use cover.open_cover instead.
See issue
In theory, a script can be an entity_id for the script.turn_on service, can it not?
In practice, I have had gpt run my scripts reproducibly just by asking it to run them without mentioning any more variables. I suspect sticking to the script name/alias is important in that case.
To go along with the add_item_to_list
I have the following working to retrieve list items:
- spec:
description: Use this function to get list of items in a ToDo list.
parameters:
type: object
properties:
list:
type: string
description: the entity id of the list to get the items from
enum:
- todo.shopping_list
- todo.house_todo
required:
- list
function:
type: script
sequence:
- service: todo.get_items
entity_id: '{{list}}'
status: needs_action
response_variable: _function_result
Be sure to update this part for your lists:
enum:
- todo.house_todo
