You may try to exclude these 3 sensors from Recorder to track.
About restrict the returned flight attributes - it is complicated as I get more request to add more attributes, or store more flights for more time
Could you post your list of attributes that you use?
Maybe there could be a setting in the configuration flow that allows defining a, say comma separated list, of returned attributes. Everything could then be returned if said setting was left empty. Just one idea, perhaps thereโs a better way to do it too.
The attributes I personally use and need in my environment are: flight_number, airline_short, aircraft_model, airport_origin_city, airport_destination_city, airport_origin_country_code, airport_destination_country_code, id, call_number, latitude, longitude
Hi, is there a way to send a notification when a specific registration number aircraft enters the area? thanks.
You just need to add condition block for the given example
automation:
- alias: "Flight entry notification"
platform: event
event_type: flightradar24_entry
condition:
- condition: template
value_template: "{{ trigger.event.data.flight_number == 'LH247' }}"
service: notify.mobile_app_<device_name>
message: "Flight entry of {{ trigger.event.data.callsign }} to {{ trigger.event.data.airport_destination_city }}"
Awesome component, as suggestion it would be great to define the watching area not only by radius but also by a set of points. For example, I am interested in one specific direction from which I can observe the airplanes and it could be defined as an ellipse.
Unfortunately, Flightradar24 doesnt allow ellipse area
Very nice integration, thank you!
I installed it today and it works like a charm.
Iโm curious, is it possible to show
Has anybody already created a card for that use case?
A list of all inbound flights can be made with the Helpers โ Utility Meter
Thanks for this nice HA integration.
I try to add this condition in a script:
condition:
value_template: "{{ trigger.event.data.altitude < '7000' }}"
But I get this error when a flight passe over my house:
Erreur : In 'template' condition: TypeError: '<' not supported between instances of 'int' and 'str'
trigger.event.data.altitude is a string or an integer?
How to modify the condition ?
Remove the quotes around 7000
Dear, has anybody a working automation (integrated into the automation.yaml) which works here. I tried several ideas, but above code doesnt work at my side. Thanks for helping, JJ
What automation did you try and did you have any errors in Logs?
I use this automation and it works well
- id: '1700072369724'
alias: FlightRadar24 notify
description: ''
- platform: event
- platform: event
event_type: flightradar24_exit
condition: []
- if:
value_template: '{{ ''flightradar24_entry'' == trigger.event.event_type }}'
then:
- service: notify.persistent_notification
message: Flight entry of {{ message}}
- if:
value_template: '{{ ''flightradar24_exit'' == trigger.event.event_type }}'
then:
message: Flight exit of {{ message}}
variables:
message: '{% set flight = trigger.event.data %} {{ flight.flight_number }} - {{
flight.airline_short }} - {{ flight.aircraft_model }} {{ flight.airport_origin_city
}}{%if flight.airport_origin_city %}<img src="https://flagsapi.com/{{ flight.airport_origin_country_code
}}/shiny/16.png" />{% endif
%} -> {{ flight.airport_destination_city }}{% if flight.airport_destination_country_code
%}<img src="https://flagsapi.com/{{ flight.airport_destination_country_code
endif %}'
mode: parallel
I live near an airport and wish to exclude aircraft that have 0 speed and 0 altitude from the card I am using. I get an error when using this syntax
type: vertical-stack
title: Flightradar24
cards:
Can someone help me out on this please. The error I am getting is
โKey โvalue_templateโ is not expected or not supported by the visual editor.โ
Can any one please help me with the syntax I need to exclude planes that are not in the air and not moving.
