I vaguely remember some warnings in my logging some releases ago about the custom component folder structure changing. I didn’t pay attention and as a result my DSMR custom component is no longer working (using the build-in component instead which is updating my usage every second…). As I seem to be unable to find information on how the new structure works I kinda need your help
What I had is:
config\custom_components\dsmr\sensor.py
What I think is needs to be (but not working) is:
config\custom_components\sensor\dsmr\sensor.py
It could be that the .py file needs to be moved / copied somewhere else?!
config\custom_components\dsmr\sensor.py is the new structure. In the past it would have been config\custom_components\sensor\dsmr.py. However, you may need a config\custom_components\dsmr\__init__.py, even if it’s just an empty file.
