Updated
Currently this will update the current state of your Freenet Funk Contract in the entity: freefunk.status
There are 4 Service Calls available:
freefunk.update --> Update the current status
freefunk.pause --> Pause the current Tariff
freefunk.book1gb --> Book the 1GB Tariff
freefunk.bookunlimited --> Book the Unlimited Tariff
The component will log the output on an INFO level.
The component is meant to enable you to: “Pause & Forget” via automations. Meaning whenever the auto reactivation (every 14days) happens, the pause can be triggered automatically if previously set by the user.
Installation
Copy all files from custom_components/freefunk/ to custom_components/freefunk/ inside your config Home Assistant directory.
Configuration
Add the following to your config
freefunk:
username: !secret freefunk_username
password: !secret freefunk_password
EXAMPLE
I added:
1x input_boolean --> represents Pause.
1x input_select --> to choose what Tariff i wish to book
input_boolean:
paused:
name: Freenet Funk Pause
input_select:
############## Tariffs ###############
tariff:
options:
- Select
- 1 GB
- Unlimited
initial: Select
icon: mdi:sim
How it looks in Lovelace:
![image](//community-assets.home-assistant.io/original/3X/2/a/2a2572047229b7d2a64566b6f1bc17e2f4204520.png)
And how i automated it within NodeRed:
Nodered Code:
"id": "b12cec59.fadeb",
"type": "inject",
"z": "5f5aa1ed.42ac5",
"name": "",
"topic": "",
"payload": "true",
"payloadType": "bool",
"repeat": "28800",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 110,
"y": 80,
"wires": [
"20b7f754.7d96c8"
"id": "20b7f754.7d96c8",
"type": "api-call-service",
"name": "Update",
"server": "2fba4297.e4145e",
"service_domain": "freefunk",
"service": "update",
"data": "",
"mergecontext": "",
"output_location": "",
"output_location_type": "none",
"mustacheAltTags": false,
"x": 500,
"y": 80,
"wires": [
"id": "a4e6db37.136d48",
"type": "server-state-changed",
"name": "Status?",
"version": 1,
"entityidfilter": "freefunk.status",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "Pause",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": false,
"x": 90,
"y": 180,
"wires": [
"37306f68.243e4"
"id": "9cb72a4c.aa3178",
"type": "comment",
"name": "Update every 8h",
"info": "",
"x": 80,
"y": 40,
"wires": []
"id": "e1bbe024.1a88",
"name": "Pause",
"service": "pause",
"data": "",
"mergecontext": "",
"x": 490,
"y": 180,
"wires": [
"f920b3.48a50f5"
"id": "37306f68.243e4",
"type": "api-current-state",
"name": "Paused On?",
"version": 1,
"outputs": 2,
"halt_if": "on",
"override_topic": false,
"entity_id": "input_boolean.paused",
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"blockInputOverrides": false,
"x": 250,
"y": 180,
"wires": [
"e1bbe024.1a88"
"id": "42b4b041.d94c1",
"type": "comment",
"name": "Pause when automatic activated, or triggered manually",
"info": "",
"x": 200,
"y": 140,
"wires": []
"id": "122877d3.440378",
"name": "Status?",
"version": 1,
"entityidfilter": "input_select.tariff",
"haltifstate": "",
"outputs": 1,
"output_only_on_state_change": true,
"x": 90,
"y": 340,
"wires": [
"83344da8.3af07"
"id": "b0312e4d.eeb12",
"type": "comment",
"name": "Book Tariffs and turn off Pause",
"info": "",
"x": 130,
"y": 300,
"wires": []
"id": "83344da8.3af07",
"type": "switch",
"name": "",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "1 GB",
"vt": "str"
"t": "eq",
"v": "Unlimited",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 290,
"y": 340,
"wires": [
"c863ecfd.0f821"
"7a2cba4c.1566e4"
"id": "a446c8e9.b8e338",
"name": "Turn Off Paused",
"service_domain": "input_boolean",
"service": "turn_off",
"data": "{\"entity_id\":\"input_boolean.paused\"}",
"mergecontext": "",
"x": 700,
"y": 340,
"wires": [
"id": "c863ecfd.0f821",
"name": "1 GB",
"service": "book1gb",
"data": "",
"mergecontext": "",
"x": 490,
"y": 340,
"wires": [
"a446c8e9.b8e338"
"id": "7a2cba4c.1566e4",
"name": "Unlimited",
"service": "bookunlimited",
"data": "",
"mergecontext": "",
"x": 500,
"y": 420,
"wires": [
"a446c8e9.b8e338"
"id": "74e15236.79407c",
"name": "Paused?",
"version": 1,
"entityidfilter": "input_boolean.paused",
"haltifstate": "",
"outputs": 1,
"x": 100,
"y": 240,
"wires": [
"e1bbe024.1a88"
"id": "f920b3.48a50f5",
"name": "Select No Tariff",
"service_domain": "input_select",
"service": "select_option",
"data": "{\"entity_id\":\"input_select.tariff\",\"option\":\"Select\"}",
"mergecontext": "",
"x": 700,
"y": 180,
"wires": [
"id": "2fba4297.e4145e",
"type": "server",
"z": "",
"name": "Home Assistant",
"legacy": false,
"hassio": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true
