Custom Component for printer ink levels
I have created a custom component which checks ink levels using the ink command in linux. sudo apt-get install ink under debian-based distros.
Currently I have not created dedicated repo for custom components. You can get the code here: https://github.com/nalipaz/home-assistant-config/blob/master/custom_components/sensor/ink.py
Just drop that into yourconfigpath/custom_components/sensor/ink.py then add the needed config documented in the comments.
  - platform: ink
    host: IP_ADDRESS
    scan_interval: 120
    resources:
     - not_present
     - black
     - color
     - photo
     - cyan
     - magenta
     - yellow
     - photoblack
     - photocyan
     - photomagenta
     - photoyellow
     - red
     - green
     - blue
     - light_black
     - light_cyan
     - light_magenta
     - light_light_black
     - matte_black
     - gloss_optimizer
     - unknown
     - light_cyan_light_magenta_photoblack
     - 2x_grey_and_black
     - black_cyan_magenta_yellow
     - photocyan_and_photomagenta
     - yellow_and_magenta
     - cyan_and_black
     - light_grey_and_photoblack
     - light_grey
     - medium_grey
     - photogrey
     - white
You really only want it to create sensors for the colors you have so after you add that you can remove the sensors that don’t provide any values.
Looks like not all printers are supported.
pi@hassbian:~ $ sudo ink -b bjnp://192.168.200.7
CRIT: udp_command: no data received (recv)CRIT: udp_command: no data received (recv)CRIT: udp_command: no data received (recv)Could not read from printer.
Could not get ink level.
Any idea how I may be able to get this to work, printer info is accessible from Remote UI in web browser after login.
I too had a similar issue when I first install ink. I restarted my pi and restarted the printer then I started getting values. However you might want to look into the supported devices for ink. If that doesn’t work you might be able to access some other way, but I wouldn’t be familiar.
Also, do realize there is by default a 120 second delay in obtaining colors. That is true upon startup of hass sometimes as well.
Been playing around with it for over an hour, so time isn’t an issue.
I tried setting up another printer which is reachable, but no info in HA.
 pi@hassbian:~ $ sudo ink -b bjnp://192.168.200.126
ink 0.5.2 © 2015 Markus Heinz
Canon MG3500 series
Black: 70%
Color: 0%
That info looks good. Curious why you aren’t getting sensors in hass. Can you show me the config for the working printer?
- platform: ink
  name: '2FL Canon MG3500'
  host: 192.168.200.126
  scan_interval: 120
  colors:
   - black
   - color
damn, bad documentation from myself. should be:
- platform: ink
  scan_interval: 120
  resources:
   - black
   - color
:+1::+1::+1: Works for the MG3500, but not for the MF8380Cdw.
Thanks.
Good to hear. For supported printers you can check out the list on libinklevel’s sourceforge page:
http://libinklevel.sourceforge.net/
Oh and looks like the developer of libinklevel does take information from users like you who might know how to retrieve info from a certain printer. Then he incorporates it, read through the aforementioned page for details on that.
Will do, Cheers!
@nalipaz can i use this on hass.io?
@Rodolfo_Vieira not without an addon to provide the ink command. I currently don’t use hass.io at my house, but it is possible I might be interested in doing an addon for this if I change to hass.io in the future. I do use hass.io for a rental property and have made one addon for that already. But as of right now, sorry no.
FYI: Reply from Developer.
“Libinklevel only supports ink jet printers.”
I went using the drivers from HP for my HP printer. It gives a tonne of info besides ink for your HP printer via command line, so I just made command line sensors for the 4 different inks.
Obviously this only works with HP printers. Not sure if other manufactures do the same.
@cjsimmons you could fairly easily convert that to a custom component if you wanted. That is all my component does, converts command line output to a bunch of sensors.
That’s pretty much what I did. I have 4 sensors for each ink cartridge, and 1 for the printer status.
placed ink.py in custom_components\sensors, but getting error:
Unable to find component sensor.ink
EDIT: you made a typo:
“Just drop that into yourconfigpath/custom_components/sensors/ink.py” need to be “sensor/ink.py”
@Martinvdm thanks for finding the issue and glad you figured it out. Corrected the initial post
