Custom Component for printer ink levels
I have been using SNMP sensor for this - works out of the box without installing anything.
How different is this component, would that be any better?
  - platform: snmp
    name: Printer Black Toner
    host: 192.168.1.106
    accept_errors: true
    baseoid: .1.3.6.1.2.1.43.11.1.1.9.1.1
    unit_of_measurement: '%'
  - platform: snmp
    name: Printer Cyan Toner
    host: 192.168.1.106
    accept_errors: true
    baseoid: .1.3.6.1.2.1.43.11.1.1.9.1.2
  - platform: snmp
    name: Printer Magenta Toner
    host: 192.168.1.106
    accept_errors: true
    baseoid: .1.3.6.1.2.1.43.11.1.1.9.1.3
  - platform: snmp
    name: Printer Yellow Toner
    host: 192.168.1.106
    accept_errors: true
    baseoid: .1.3.6.1.2.1.43.11.1.1.9.1.4
The ink2mqqt component uses ink and libinklevel (http://libinklevel.sourceforge.net/) and the results are available via MQTT. For a list of supported printers see the sourceforge-link.
I’m not sure but I’m expecting that a printer that supports SNMP is not supported by Ink/Libinklevel.
I know that certain HP printers require Cups and HPLib. So, the use of this addon will be somewhat limited.
I’m not using this ink2mqtt.sh script. I’m using something else that runs 2 commands against hp-info. 1 command for the printer status, and the other that runs once for each ink cartridge. This doesn’t work on hass.io.
Thanks mate. Works a treat.
Yes, I know. I tried to create an add-on that has both Cups and HPLIP, but I got stuck at compiling HPLIP :frowning:
well, i have an Hp ENVY inket printer, running hass.io, if anyone can find/make an addon , i’m verry happy :slight_smile: , since i am unable to install extra components
This is what I use for my HP printer:
It may work for yours.
Got it from:
- platform: snmp
  name: 'Printer Ink - Black'
  host: 192.168.1.135
  baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.1
  accept_errors: true
  scan_interval: 86400
- platform: snmp
  name: 'Printer Ink - Yellow'
  host: 192.168.1.135
  baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.2
  accept_errors: true
- platform: snmp
  name: 'Printer Ink - Cyan'
  host: 192.168.1.135
  baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.3
  accept_errors: true
- platform: snmp
  name: 'Printer Ink - Magenta'
  host: 192.168.1.135
  baseoid: 1.3.6.1.2.1.43.11.1.1.9.1.4
  accept_errors: true
Do you have a laser or inktjet?
I have an inkjet
Cool, gonna try it out after holiday :wink:
Also an envy model?
No it’s a photosmart, if it doesn’t work I’ll run through how you find the baseoids for your printer (if it supports SNMP)
I have an hp envy as well. I can see ink levels change when I print a diagnostic report but I can’t see those numbers in the SNMP query. Whole bunch of stuff but not those numbers. The numbers that are close are not changing
mine look identical as yours, even the values, also hp eny owner here…
I have a Canon MX922 printer and when I tried the steps above, I am getting a:
Timeout - No response for 192.168.1.xx.
When executing the the command:
snmpwalk -v2c -c public 192.168.1.xx
Am I doing something wrong?
Just finished setting up the OP’s version of the Ink Custom Component on Home Assistant 0.98.5 and figured I’d provide an updated set of installation instructions. I am running HA in a venv on an Ubuntu 18.04 VM in ESXi 6.0. My printer is a Canon MX922
Please note, these steps are NOT for HASSIO. They also assume you have a basic understanding of working with linux and linux file permissions.
  1. SSH into your HA instance
  2. Install the Ink command
    sudo apt install ink -Y
  3. Navigate to /<your-ha-root-directory/custom_components/ (Note: For a venv, the default root folder location for HA is /home/homeassistant/.homeassistant/)
  4. Create a 0.92 compatible folder for the Ink component.
    sudo mkdir ink/
  5. Download the Custom Component from the OP’s github. The link below is the correct link to the raw version of the file.
    sudo wget https://raw.githubusercontent.com/nalipaz/home-assistant-config/master/custom_components/sensor/ink.py
  6. Rename ink.py to sensor.py. (Note: This was the only way I could get the Ink component to load in my environment.)
    sudo mv ink.py sensor.py
  7. Create and edit manifest.json
    sudo touch manifest.json
    sudo nano manifest.json
  8. Copy/Paste the following into manifest.json exactly as shown. Spacing is important!
    "domain": "ink",
    "name": "Ink",
    "documentation": "https://github.com/nalipaz/home-assistant-config/blob/cc688694f96e60783917197613a9e24224eb05ae/custom_components/sensor/ink.py",
    "dependencies": [],
    "codeowners": ["@nalipaz"],
    "requirements": []
  1. Save the file and exit.
    Control+X, then Y, then Enter/Return
  2. Verify that the ink subfolder, and the manifest.json and sensor.py files are owned by the home assistant user/service account.
  3. Tail (i.e. watch) the home-assistant.log file to ensure the component loads correctly when executing step 12.
    tail -f /<your HA directory>/home-assistant.log | grep ink
  4. Restart Home Assistant via the Home Assistant UI
If you see messages similar to the following, you know you’ve set up the Custom Component correctly.
2019-09-09 10:43:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for ink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-09-09 10:43:03 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.ink
The next step is to configure your printer in sensor.yaml as outlined in the first post of this thread. Be aware that if you have logging (i.e. logger:) enabled in your configuration.yaml, you will flood home-assistant.log with an error for each and every color listed under resources: that is not supported by your printer. These errors will repeat at every scan interval. In this case, you will want to cull your list of supported colors quickly to avoid crashing HA.
For those of you with a Canon MX922, here is the sensor.yaml config that worked for me.
  - platform: ink
    host: <your-ip-here>
    scan_interval: 120
    resources:
     - black
     - cyan
     - magenta
     - yellow
     - photoblack
Once you’ve added the entry in sensor.yaml, Check your Config via the HA UI, then Restart HA once more if everything checks out. Once the reboot is complete, you should see new sensor entries in your entities list similar to the ones in the screenshot below.
Hopefully this will helps others. Let me know if you encounter any errors with these instructions.
And a Big Thanks to @curt7000 for pointing out the new manifest.json requirement that was added in 0.92.0.
Hi @nalipaz
need some help here, i’m putting the file like written, please look below:
in configuration.yaml
when i check the configuration file, i get the error below:
what am i missing?
Thank you for your help
Not using it myself but think the folder that ink.py is in should be ink and not sensor
tried, same error
See @daphatty’s post above, think you need to rename ink.py to sensor.py and add a manifest file
tried, same error
You are restarting after you changed it ?
