I have extactly the same problem as Thomas had, MQTT communication is working well but the data ist not shown in HA. Micheal, you have solved it by adding a leading slash th the prefix (e.g. /go-eCharger/020152) in the go-e App, but in my go-e App version I have no possibility to enter a prefix … see picture
At last I decided to implement the “new” much sleeker and simpler automation. Kudos to @syssi for bringing it this far!
I have perfect mqtt response and see all relevant sensors (total solar power and excess power for charging) in my HA panel. All good. But when I add the automation to my automations.yaml like this:
Then I get the following indentation error and can’t get rid of it for the life of me:
bad indentation of a mapping entry (196:32)
193 | qos: 0
194 | retain: false
195 | topic: go-eCharger/097828/ids/set
196 | payload: {{'{"pGrid": '}}{{states('sensor.total_availabl ...
197 | mode: single
198 | - id: '1688104739643'
If I then save my automations.yaml file anyway and try to restart HA then the configuration.yaml loading gives the following error:
Error loading /config/configuration.yaml: while parsing a block mapping
in "/config/automations.yaml", line 193, column 7
expected <block end>, but found '{'
in "/config/automations.yaml", line 196, column 32
Any clues anybody?
EDIT:
So found the right formatting of payload to be:
Hi.
I have a problem with charging the vehicle with three phases.
I have the charging current limit set like this:
Maximum current limit - 16A
Requested current - 16A
When charging the overproduction of energy by the solar system with one phase, the current rightly reaches 16A, and still exports energy to the grid from two unloaded phases (3.6kW).
When overproduction is greater, the go-eCharger switches to three-phase charging, but splits the maximum current into three phases, and charges roughly 6A per phase, and still exports to the grid (3kW).
Shouldn’t the energy limit apply to charging with three phases of each phase separately?
i tried the approach but even the Mode is set to ECO with Surplus Charging the device loads with more than what is reported in the pGrid. All three phases are loading with 3+kWh even only 1.3kWh is reported. The charger also does not stop after the surplus drops below the minimum threshold.
Hi, I tried to configure, but got the following message in the mosqiuto log:
2023-09-24 13:19:30: New connection from 192.168.178.147:56172 on port 1883.
error: received null username or password for unpwd check
2023-09-24 13:19:30: Client go-echarger_212162 disconnected, not authorised.
Hi, have you managed to publish a mqtt setting frc state to charging ? I’m also using EVCC but i would like that my EVCC setup is not dependent on E-go Custom component.
My automation for setting CarConnected looks like this
Hallo @syssi ,
Thank you for your effort to set this integration up.
I read through the entire post. It reads very well.
I still have a question: Does your integration allow for more than one go-e charger to be controlled via the integration within Homeassistant?
I have two chargers connected to each other (well, basically not yet but they already mounted to the wall only waiting for the electrician to connect them to the house electricity net.) with load management etc. and a PV solar system. I’d like to provide the two chargers with the PV excess energy and depending on the EV connection status charge only one vehicle or share the engergy between the two.
Will this work with the integration?
Do you have a Linux host and are you able to use mosquitto_sub to record a bunch of MQTT messages? I would like to reproduce the issue locally by replaying your recording.
Hello
I encountered the same issue. When adding a leading slash to the go-echarger Prefix in the App I finally was receiving all the data. @syssi: Thanks a lot for the great integration and support. It took me some attempts but finally while carefully reading through the posts I could make it running. Just fantastic work syssi, well done! Also thank a lot for adding the additional buttons to start / stop the charger!
I have uninstall everything and installed again. Was not working.
I downgrade the charger firmware to 55.7. Was not working.
I just upgrade the firmware to 56.1 ( latest ) again and now all is working.
