I’ve prepared a custom component to consume the MQTT messages of the go-eCharger MQTT API v2:
I would be happy about some beta testing and support of the heavy EV charger users. Naming and value transformations could be improved step by step.
I installed this integration yesterday so I will start playing with it soon. I just got my box two days ago and was planning to use a different integration. But it did not show up in HACS and this one did and I already have MQTT running at home so I thought I would give this a go.
So far I have only seen that it works with reading values and I was able to change the amp setting from HA and confirm that it worked. And for the moment that is all I need.
The plan is to use this integration combined with my solar inverter integration to implement a load guard to allow the charger to use as much power as it can at all times without blowing any fuse(s)
The presence of a supported local API, and the fact that it is also portable, was the reason I chose this box since I could then have a load guard without any additional HW since my inverter already has a power meter.
is there anything like a installation guide i hav no idea from MQTT but ne i have the GOE Charger an would like to control ist with my HA…
Please google for “homeassistant mqtt beginners guide”. As far as I know there a two ways to setup a MQTT broker:
apt-get install mosquitto
As next step you’ve to add the “MQTT integration” to connect your broker (host + port):
http://localhost:8123/config/integrations -> Add integration -> MQTT
As soon Home Assistant is connected to your MQTT broker install the “go-e charger component” and tell your go-e charger to push data to the broker (Android app → Internet → Erweiterte Einstellungen → Aktiviere MQTT API [x] → mqtt://192.168.x.xxx:1883). The data should be visible at Home Assistant immediately.
Please create an issue at the project repository if you need additional support.
I have installed the integration but the new sensors does not appear in the Developer tools. I’m running mqtt already for Zigbee2mqtt, and go eCharger is configured with mqtt.
Where do I configure the 6 digit serial number?
Please restart Home Assistant once and go to “Configuration” → “Devices & Services” → “Add integration” and add the “go-e charger (mqtt)” integration. You will be asked about the serial number here. Do you know the serial number of your device already?
Thanks for the quick reply - it appeared under “Devices & Services” this morning, and it just needed to be configured. The serial was in the device name. I did not have to enter it.
It works now. I get the data live now and can change the amps, which is just what I needed.
Thanks again for a solid component.
THX syssi!
The integration is working really well. Only thing is, that energy consumption is given in wh not kwh.
I would like to add it to the energy dashboard.
Best regards,
Stefan
The energy dashboard requires kWh and doesn’t support Wh? If this is the case I will change the unit.
I just checked it again. I think it accepts wh but needs a last reset.
The failure is
Letzter Reset fehlt
Die folgenden Entitäten haben die Zustandsklasse "measurement", aber "last_reset" fehlt:
sensor.go_echarger_xxxxxx_wh
Letzter Reset fehlt
sensor.go_echarger_xxxxxx_cards
ok, maybe go-e never resets it
I found this:
Best regards,
Stefan
Do you use the most recent release of the custom component? Because the state class is total_increasing
already: Use STATE_CLASS_TOTAL_INCREASING to be energy dashboard compatible (C… · syssi/homeassistant-goecharger-mqtt@b7edc02 · GitHub
Hello syssi,
yes I used your last version 0.10.0 via hacs. It was working fine until yesterday afternoon.
An update of ha os came in and I installed it. I use ha in virtualbox
Now I don´t get a connection from go-e anymore. Everything stays at unavailable.
My Mosquitto runs as HA-addon.
I get this in log
1648903522: New connection from 172.30.32.1 on port 1883.
1648903522: New client connected from 172.30.32.1 as dc8cf344 (p2, c1, k15).
1648903525: New connection from 192.168.88.145 on port 1883.
{"result": "ok", "data": {}}1648903525: New client connected from 192.168.88.145 as c6dea259 (p2, c1, k15, u'mqtt').
1648904703: Saving in-memory database to /data/mosquitto.db.
1648905979: New connection from 192.168.88.155 on port 1883.
1648905979: Client go-echarger_077102 already connected, closing old connection.
I really don´t know what to do. So, it seems the charger connects to broker, but why is it closed again?
I spent now more than 6 hours to get this fixed. Reinstalled mosquitto addon, go-e addon. Changed fw of go-e to beta and back. Turned off go-e.
I have a laptop running with HASS.Agent GitHub - LAB02-Research/HASS.Agent: Windows-based client for Home Assistant. Provides notifications, quick actions, commands, sensors and more. which connects just fine to moscitto.
Any help would be nice. The other go-e addon is working, but only with api1 and its not as nice as yours.
Best regards,
Stefan
Which go-e firmware version do you use? Is Home Assistant (MQTT integration) able to connect to the broker?
I use 053.1
I use HASS.Agent which connects fine to the MQTT Addon and everything works. So I think MQTT Integration is working
Is it possible that you somehow managed to install the custom component twice?
I will check it this evening. I installed it via HACS
Some details about my local setup for comparability:
$ dpkg -l | grep "mosquitto "
ii mosquitto 2.0.14-0mosquitto1~bullseye1 amd64 MQTT version 3.1/3.1.1/5.0 compatible message broker
$ grep charge /var/log/mosquitto/mosquitto.log
1648995409: New client connected from 192.168.1.11:58084 as go-echarger_072246 (p2, c1, k120, u'sensors').
$ netstat -tn | grep 192.168.1.11:
tcp 0 0 192.168.1.100:1883 192.168.1.11:58084 ESTABLISHED
I like the command line tool mosquitto_sub
to subscribe and make some traffic visible:
$ mosquitto_sub -h <BROKER-IP> -u <USERNAME> -P <PASSWORD> -t '/go-eCharger/#' -v
/go-eCharger/072246/alw false
/go-eCharger/072246/acu null
/go-eCharger/072246/adi true
/go-eCharger/072246/dwo null
You could use any other client software to subscribe to the go-eharger topics. The MQTT integration of Home Assistant also provides some small client for debugging. Please go to
Configuration → Devices & Services → MQTT integration “configure”
The last card is called “Listen to a topic”. Please try to listen for “/go-eCharger/#” messages. Do you see any traffic? If there is no traffic: Please subscribe to “#”. Now you should see every arriving message (at the broker). If there is no traffic try to publish a message manually. The topic and the payload isn’t important.
Now you should be able to answer the following questions:
@Jpsy
no, its installed only one time
Nachricht 888 empfangen auf homeassistant/sensor/DESKTOP-T1ECMFD/LastActive/state um 16:46:
2022-04-03 14:46:11Z
QoS: 0 - Retain: false
Nachricht 887 empfangen auf homeassistant/switch/DESKTOP-T1ECMFD/MediaMute/config um 16:46:
"availability_topic": "homeassistant/sensor/DESKTOP-T1ECMFD/availability",
"command_topic": "homeassistant/switch/DESKTOP-T1ECMFD/MediaMute/set",
"unique_id": "1f452925-ac26-4cde-8b69-f3491508c0f1",
"device": {
"identifiers": "hass.agent-DESKTOP-T1ECMFD",
"manufacturer": "LAB02 Research",
"model": "Microsoft Windows NT 10.0.22000.0",
"name": "DESKTOP-T1ECMFD",
"sw_version": "2022.3.27.0"
"name": "MediaMute",
"state_topic": "homeassistant/switch/DESKTOP-T1ECMFD/MediaMute/state"
If your broker is password protected you have to embedded username and password in the URL:
mqtt://username:[email protected]:1883
