I agree it only shows up in the installed integrations but it should be listed there all the time whether there is an update available or not. Mine is there now with no update available.
I can’t seem to see the python scripts
tab despite ticking the box when adding the HACS integration.
Anyone having this issue?
You need:
python_script:
In configuration.yaml and it will be in HACS
cheers…classic case of RTFM
I have from time to time the issue that HACS refresh is not coming to an end. I have to restart hass.io to end this. Anyone some similar issue?
Since you mentioned it…I had seen it once before, but today I saw it again (using plain old Hass).
This time I see a log entry that is perhaps related:
File "/home/tommy/.homeassistant/custom_components/hacs/hacsbase/__init__.py", line 304, in recuring_tasks_installed
await self.factory.execute()
File "/home/tommy/.homeassistant/custom_components/hacs/hacsbase/task_factory.py", line 24, in execute
await asyncio.gather(*self.tasks)
RuntimeError: cannot reuse already awaited coroutine
same here. running since half an hour on my nuc
i do all the steps according to this guide:
i using hassio 104.3 but i dont have any community left menu ?
I get the success message and nothing failed, what to do ?
Did you restart home assistant?
I see a lot of these :
2020-01-21 14:48:34 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/config/custom_components/hacs/hacsbase/__init__.py", line 304, in recuring_tasks_installed
File "/config/custom_components/hacs/hacsbase/task_factory.py", line 24, in execute
2020-01-21 15:00:23 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2020-01-21 15:18:35 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 15:48:36 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 16:18:37 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 16:48:38 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 17:18:39 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 17:48:40 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 18:18:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 18:48:42 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 19:18:43 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 19:48:44 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 20:18:45 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 20:48:46 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 21:18:47 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 21:48:48 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 22:18:49 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 22:48:50 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 23:18:51 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-21 23:48:52 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 00:18:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 00:48:54 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 01:18:55 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 01:48:56 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 02:18:57 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 02:48:58 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 03:18:59 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 03:35:59 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/config/custom_components/hacs/hacsbase/__init__.py", line 322, in recuring_tasks_all
2020-01-22 03:49:00 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 04:19:01 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 04:49:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 05:19:03 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
2020-01-22 05:49:04 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
Stop looking at your logs.
Same here, happens quite regularly and over the last 5+ versions of HACS.
Restart of HA fixes it.
I’m seeing a couple of HACS errors in the logs:
and
GitHub returned 502 for https://api.github.com/repos/JAAlperin/hass-bardolph/commits/maste
It’s the same here
Hello everybody
Trying to install HACS, after I put the GIT hashcode, waiting a lot, I receive a ‘Unknow error’
This is in the ha registry:
020-01-28 12:17:35 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-28 12:18:28 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 830, in _resolve_host
self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.7/site-packages/aiohttp/resolver.py", line 30, in resolve
host, port, type=socket.SOCK_STREAM, family=family)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 788, in getaddrinfo
None, getaddr_func, host, port, family, type, proto, flags)
File "/usr/local/lib/python3.7/socket.py", line 752, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
It repeats the same 5 times, then again and again…
Any solution?
Does your DNS are well configured ?
Your error message appears to be DNS related. Does DNS work on your home assistant instance?
It does say
A stable internet connection with a sufficient bandwidth
which implies DNS as it is an integral part of the internet.
My DNS seems to works perfectly. Zero problems with Firefox or other internet related programs.
You run firefox on your home assistant computer?
