Custom Component: HACS
Manage (Install, track, upgrade) and discover custom elements for Home Assistant directly from the UI.
What?
HACS is an abbreviation of “Home Assistant Community Store”.
Although “Store” is not “technically” correct since nothing is sold, it’s more like a marketplace? but “HACM” didn’t have the same ring to it.
HACS is a component that gives the user a powerful UI to handle downloads of custom needs.
Highlights of what HACS can do:
  • Help you discover new custom elements.
  • Help you install (download) new custom elements.
  • Help you keep track of your custom elements.
    • Manage(Install/Upgrade/Remove)
    • Shortcuts to repositories/issue tracker
Why?
About half a year after the first version of custom_updater, I started to hate it, really hate it and I didn’t see any way of getting it to a state where I would have been happy with it, most of my issues with that you can find here https://github.com/custom-components/custom_updater/issues/117.
With the amount of users it had/have(/has?) I figured it would be better to start over with the same “mission”, that’s where HACS came to life.
HACS is not a full replacement for custom_updater and even though their “mission” is the same how they work is completely different, where the main issue is to make it easy for both the user and the developer, for most elements it will just work (with some exceptions of course).
Useful links
Issues
If When you experience issues/bugs with this the best way to report them is to open an issue in the repository https://hacs.xyz/docs/issues, GitHub is AWESOME for tracking/searching issues.
So again, since this is kinda important, If when you experience issues/bugs with this, post them to GitHub, not here.
Issues posted in a forum thread is really, really, really hard to track/follow :slight_smile:
The same goes for feature requests.
HACS question about adding repositories
Lovecard installation via HACS
Why not add them as components
Philips Android TV Ambilights (Light) component
Bwalarm (akasma74 edition)
HACC - Home Assistant Command Center
Sonoff ifan02
HACS error
ZHA Zigbee Tested Devices...Please add your device results
Connected VAG/PON cars
Smartthings or Zwave USB Stick
HACS issue
Garbage pickup date (mijnafvalwijzer.nl) custom_component
A different take on designing a Lovelace UI
Clean Tile-Based Lovelace UI - only 2 cards needed!
VegTrug Grow Care Garden (MiFlora like sensor)
Zigbee2mqtt: show the networkmap in home assistant
Google calendar integration fails
Costum Cards Error - wrong folder path?
Hive Integration
KeyMaster Z-Wave lock manager and scheduler
Stream Twitch audio to media player
Integrations Page?
TP-Link Kasa Smart Wi-Fi Plug with Energy Monitoring
Jandy iAqualink Pool Integration
Rollease Acmeda Automate Pulse 2 hub integration
How do I get my plugin added to HACS?
Output speech to Alexa based on state
Person Detection Using AWS Rekognition and Node-Red
I made a crappy Nest Thermostat integration that will work as a stopgap until alternatives come out
Make a custom card (iCloud3)
Any way to force some users to a dashboard other than Overview?
FordPass Integration
How to convert kb/s to mbps in a sensor template?
Insteon Thermostat 2441TH for ISY
Deprecated - Custom Component Krisinformation (Sweden)
Control TiVo box over telnet
Echo Devices (Alexa) as Media Player - Testers Needed
Goodwe rest sensor for multiple json elements
Traccar via Nabu Casa webhooks
Light status from another sensor
Netgear Enhanced (sensors and switches for router controls)
Ifan03 with tasmota to ha
Arlo: replacement pyarlo module
ADT Pulse integration
AlarmSystem with appdaemon
Starting with intergrations and can't get them running
[TESTERS NEEDED] Android TV / Fire TV key generation
Entity on front end
Unable to make custom cards work
Dual Thermostat Card
Very interested in trying this out.
I am reading through your documentation - step 5 says to see step 7… but I think this is suppose to be step 6.
On the same token, in step 6 it says to go back to step 6… I think this is suppose to say go back to step 5.
I’m going to try and install this soon and see how it works (running on Linux with Docker HA container install).
Cheers!
DeadEnd
Awesome!
There are probably many, many, many other flaws there.
When you find them there is a edit button on every page, if you find something wrong it would be greatly appreciated if you submit a PR to correct that :slight_smile:
Will do.
I am still new to Github, but I’ll do my best to do it correctly :slight_smile:
DeadEnd
Ok tomorrow’s task will be to uninstall custom_updater and try this out.
Is there a list of compatible custom components I can browse before installing?
A list like that would not be possible to make, any GitHub repository that follow the requirements can be added :slight_smile:
By default any card in https://github.com/custom-cards or component in https://github.com/custom-components is included (as long as they follow the requirements), as well as a handful of other repositories added by their respective developers. You can add repos that aren’t in the default set to HACS from the settings tab, but, as @ludeeus mentioned, they need to follow the requirements for HACS.
Yeah I was after a list of the ones that do follow the requirements.
Let me try that again :slight_smile:
A list like that is not possible to create/maintain, any compliant GitHub repository can be added as a custom repository, if you are after the default ones that’s is more manageable, but not something I would make since there would be to much to maintain.
Yesterday I converted most things from custom updater to HACS successfully. This is just awesome! Thanks a lot!
I had one updated plugin during the process, but almost missed it because I did not notice the orange color of the icon. Perhaps it’s an idea to also change the fontcolor of the name as well?
Please open a feature request on the issue tracker for that :wink:
I’m aware, but since that’s not really possible I thought I would offer a bit more info. :slight_smile:
The only ones I use not supported are the custom dark-sky animated card (@mpfranklin) and sun custom component (@pnbruckner) and believe it or not @ludeeus own authenticated sensor. All the rest are in there now. (All were previously supported by custom_updater)
Other custom_components not included that I use are alexa_media and life360. Tho, life360 will hopefully soon become a full component so it won’t be needed.
I was able to manually add a few other lovelace plugins that I use but several weren’t able to be added since they weren’t compatible.
Heck, I was even able to get my own fan control lovelace plug in added to the default store so if I can figure out how to do that then anybody can. :smile:
If you restart HA, it is now :slight_smile:
https://i.ibb.co/h8kzKLT/image.png
Nice… a reload made it showup too so loaded and then restarted. Thanks.
I’d like to switch to this, and make my own custom cards compatible, but it appears that I can’t do this without breaking their existing compatibility with custom_updater.
Currently they support the “super_custom cards” method of custom_updater which requires the name of the Javascript file to exactly match the repo name, but it seems that the new HACS component requires the Javascript file to exclude the lovelace- prefix if present in the repo name. Since my repo names start with lovelace-, it seems I can only support one or the other but I don’t want to exclude those who haven’t yet updated to use HACS. Is there any way around this?
I can maybe fix that limitation, got a link to a repo with that?
Here is one of my repos for a custom card, which currently works with custom_updater:
Should be acceptable in 0.8.0 when that drops :wink:
