Yeah, fair enough. I think I knew that there would be people who liked it as it was!
Yes it is… My main ‘issue’ is the truncated route.
But whatever @eifinger chooses to do, I’m basically very happy!
Did you get a chance to look at what the default scan_interval is?
I have 5 sensors set up and my dashboard shows that I have used very nearly 27,000 api calls in only about three days:
At that rate I think I will go through the 250,000 limit well within a month.
scan_interval changed from 30 seconds to 300 seconds (5 minutes). This can be overridden by defining scan_interval in the configuration.scan_interval in the docs (info.md and README.md)unit_system in the docs (info.md and README.md)@klogg: The possibility to change the unit_system was there all along. I forgot to put in in the docs. Sorry
The default scan_interval for sensors is 30s. I set the default to 300s. This can be changed by defining scan_interval in the configuration for each sensor.
@JozMar: Your error is fixed in this release. Its actually a wrong configuration of the sensor itself but now you should get a meaningful error message that helps you fix it. Please let me know if this works for you.
I am sorry I did not really get your point. Could you try to explain it again?
Currently the implementation is:
traffic_mode: true Returns the actual current valuetraffic_mode: false Returns estimated value based on historic dataI also found out that you can provide departure or arrival options. I will implement them in the future.
Does the truncate only happen on the state/lovelace representation of the sensor? Could you check under /dev-state if the attribute value is truncated there also?
If not you could implement your own truncate algorithm with a template sensor until I have decided on the best implementation option.
Just updated to 1.2.0, changed to imperial units and now the distance and duration are shown in about 10 decimal places, is it possible to round it to 1 decimal place ?
Ah, that was the information I asked for.
My understanding was, that Here combines both methods. If you plan a long distance journey, it calculates on the one hand the current traffic. But as you will arrive your destination maybe in several hours, here uses historical information of the destination to estimate the duration more accurate.
I wasn’t sure, if that is a special function only for professional use.
Is there an usecase which can’t be implemented by an template sensor which rounds the value?
No I guess not but I’d have to make 2 template sensors for each of the HERE sensors ? Would just be nice in each of the HERE sensors. Not a problem though, was just a suggestion. Thanks again for making this.
I’m glad you have a use for it. I don’t want to force a rounded value as I’m sure somebody else does have a use for it
My log fills with
2019-07-17 11:07:01 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.home_to_work fails
File "/srv/ha/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "/srv/ha/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 380, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
File "/home/homeassi/.homeassistant/custom_components/here_travel_time/sensor.py", line 215, in update
self._here_data.update()
File "/home/homeassi/.homeassistant/custom_components/here_travel_time/sensor.py", line 293, in update
if not re.fullmatch(pattern, self.origin):
File "/srv/ha/lib/python3.7/re.py", line 178, in fullmatch
return _compile(pattern, flags).fullmatch(string)
TypeError: expected string or bytes-like object
Does anyone else see this?
Could you please open an issue for that with the version installed, your config etc under https://github.com/eifinger/here_travel_time/issues
Thank you
Sure…done.
Yes I’ve the same errors, added a comment on Github
Don’t know if you changed anything but durations are now with only 2 decimal places. The distance is still showing 51.017060367454064, not sure if that accuracy is needed !
Hi, tip for all who are struggeling with this extremely accurate duration and distance:
Use the waze-card.
Looks like this
You can get it in hacs
Config:
entities:
- entity: sensor.here_sensor1
name: way to destination
zone: zone.destination
- entity: sensor.here2
zone: zone.home
title: Way to work
type: 'custom:waze-card'
@eifinger
Thanks for the changes. Works great now.
@Holdestmade @VDRainer I identified the bug and will release a fix soon.
Upgraded, works without issues
Deprecated - replaced by this:
