Custom Component: here_travel_time
Yes, its mentioned in Hacs. There you still have to look for Waze-Card.
I added the new github page https://github.com/ljmerza/travel-time-card to HACS and installed it that way
thanks, it works
@klogg I tried to recreate your issue and got a route with 444 characters. Could you share your config which creates your truncated route here?
After a succesfull install with HACS I get the following error:
Platform not found: sensor.here_travel_time
What can I do?
Thanks.
Can you copy in the full error, and the relevant configuration.yaml section for your sensor?
This will help identify where the issue might be.
Sorry, I’ve been away a bit and a also involved with real life over the last few days.
I looked again today at this and yes, it looks like it must have just been the Lovelace more info box that was truncating the route.
I’m really sorry to have brought this up without properly checking first.
No worries I am glad you could solve it :+1:
So how would someone make an automation to only have this run when you are away from home? I saw the example on how to make it run more often, but nothing about less often. Seems like a waste to make calls while I’m zero mins from home all night.
I’m also getting the same issue. Not sure what is wrong, as I copied the example and changed the values to suite my setup.
There is no error in the log. It just won’t work.
Here is my code.
  - platform: here_travel_time
    name: "here: Home to UOW"
    app_id: !secret here_app_id
    app_code: !secret here_app_code
    origin: zone.home
    destination: zone.uow
I do it like this for two sensors:
(One is time to home which you asked about, the other is from home to somewhere else based on whether I am home and the contents of a calendar event. I have removed identifying details so I hope it all still makes sense)
EDIT: I forgot to add that the actual sensors have a long scan_interval (of course).
#=== Automations
automation:
  #=== Person1 Here Routes sensors
  - alias: Here Routes when Person1 leaves or arrives Home
      - platform: homeassistant
        event: start
      - platform: state
        entity_id: device_tracker.person1_composite
        to: 'home'
      - platform: state
      #== stop the looping scripts for Person1 to Home
      - service: homeassistant.turn_off
        entity_id:
          - script.set_person1_to_home_update_interval
          - script.loop_set_person1_to_home_update_interval
      #== stop the looping scripts for Home to Somewhere Else
        entity_id:
          - script.set_home_to_somewhere_else_update_interval
          - script.loop_set_home_to_somewhere_else_update_interval
      - delay: "00:00:02"
      #=== Start the loops
      - service: script.set_person1_to_home_update_interval
      - service: script.set_home_to_somewhere_else_update_interval
#=== Scripts
script:
  #=== PERSON1 TO HOME
  #=== Set update interval for Person1 to Home sensor
  set_person1_to_home_update_interval:
    sequence:
        entity_id: script.loop_set_person1_to_home_update_interval
      #=== Call the looping script to set the interval for Person1 to Home
      - service: script.loop_set_person1_to_home_update_interval
        data_template:
          interval: >
            {% if states('device_tracker.person1_composite') == 'home' %}
              12:00:00
            {% elif states('device_tracker.person1_composite') != 'home' and
                    states('sensor.person1_local_time_offset') != '0.0' %}
              12:00:00
            {% else %}
              00:00:30
            {% endif %}
  #=== Looping script that sets the Person1 to Home sensor interval
  loop_set_person1_to_home_update_interval:
    sequence:
      #=== update the sensor
      - service: homeassistant.update_entity
        entity_id: sensor.person1_to_home
      - delay: "{{ interval }}"
  #=== HOME TO SOMEWHERE ELSE
  #=== Set update interval for Home to Somewhere Else sensor
  set_home_to_somewhere_else_update_interval:
    sequence:
        entity_id: script.loop_set_home_to_somewhere_else_update_interval
      #=== Call the looping script to set the correct interval
      - service: script.loop_set_home_to_somewhere_else_update_interval
        data_template:
          interval: >
            {% if states('device_tracker.person1_composite') == 'home' and
                  is_state('binary_sensor.reminder', 'on') and
                  '(H)' in state_attr('calendar.somecalendar', 'message') %}
              00:05:00
            {% else %}
              12:00:00
            {% endif %}
  #=== Looping script that sets the Home to Somewhere Else sensor interval
  loop_set_home_to_somewhere_else_update_interval:
    sequence:
        entity_id: sensor.home_to_somewhere_else
I’m using a long scan_interval for the sensor and a custom:button-card that shows the sensor and updates on long press.
20190722_09%3A50%3A47_001
              - type: custom:button-card
                layout: icon_name_state2nd
                entity: sensor.home_to_work
                name: Home -> Work
                icon: mdi:car-back
                show_state: true
                show_label: true
                label_template: >
                  return (states['sensor.home_to_work'].attributes.route.includes("St1234") ? 'Route 1' : 'Route 2')
                color: var(--my-green)
                tap_action:
                  action: more-info
                hold_action:
                  action: call-service
                  service_data:
                    entity_id: sensor.home_to_work
                styles:
                  name:
                    - justify-self: end
                    - padding-right: 20px
                  state:
                    - justify-self: end
                    - color: var(--primary-color)
                  label:
                    - justify-self: end
                    - font-size: 14px
                state:
                  - value: 30
                    operator: '>'
                    color: var(--my-red)
                  - value: 20
                    operator: '>'
                    color: var(--my-yellow)
I have exactly the same message, when I check my config against 0.96.3.
I’m still on 0.95.4 and everything is working fine.
My number of api-calls have decreased rapidly since the last changes last week.
@cjsimmons @brugk000 Could you please open an issue under https://github.com/eifinger/here_travel_time/issues and include your HA version? Thanks!
New Relase v1.3.0
Breaking Changes
Changes
Features
  • Route is now populated for Public Transport and Pedestrian
Bugfixes
New Relase v1.3.1
Breaking Changes
Changes
Features
Bugfixes
  • Hotfix Public Transport Route Generation
already done
It’s [quote=ā€œeifinger, post:94, topic:125908ā€]
[/quote]
Sorry I haven’t opened an issue yet, but saw it’s now at 1.3.1, so thought I’d try that first and it’s now working.
What installation method of homeassistant are you using? hass.io?
In v1.3.1 nothing is changed which would fix the error… strange
I’m using Hassio. Not sure why it started working then. Both installed manually and via HACS were failing for me.
Now it’s working, and works great. It’s interesting to compare travel times with Waze, and soon I’ll look at the other options here offers.
