I installed it again and ignored the error.
Restarted manually through ssh and it works now
Thanks for the assistance.
New Relase v1.4.0
Breaking Changes
Changes
- Added additional attributes
origin
anddestination
to fully support travel-time-card by @ljmerza - Code is now using type annotations
Features
Bugfixes
I already checked my 0.95.4 vs 0.96.5 and got the known error again
- Platform not found: sensor.here_travel_time
IT was solved some days ago.
Iām also getting this error:
when I check configā¦ Is the accepted solution simply to restart anyway and just power through?
Yep. If it still wonāt work feel free to report back
It workedā¦ Hass.io refused to reboot so I had to restart it from the command line, but when it came back it was runningā¦
The results shown for my commute to work donāt match what I get from the here app, thoughā¦ The route also only shows part of the trams/busses I would need to work and the time is quite a bit differentā¦ Is there a way to check itās working properly? Itās getting the locations right, I can see that.
So after some playing around with the API a bit, it looks like publicTransport doesnāt work well in my region, but publicTransportTimetable does (matches results I get from the app)ā¦ Iām guessing this has to do with missing realtime transport information for some lines hereā¦ I tried just adding it to all your enums and using it as an option but that wasnāt enough to make it work ;-).
New Relase v1.4.2
Breaking Changes
Changes
Features
Added
mode: bicycle
Added
mode: publicTransportTimeTable
- Please look here for differences between the two public modes. -
Release notes are shown in HACS depending on your installed version
Bugfixes
@scstraus let me know if this works out for you =)
Big upvote from me!! Will see if I can find the time to test it before I head to vacation, thanks!!
I gave it a try, but unfortunately am getting an error:
API returned error No timetable route found.
I will send you a PM with the URL I use to get the route from the API which gives me good resultsā¦ Same as what I have programmed into the sensor.
Canāt add custom repository in settings of HACSā¦ Canāt it be put in HACS store like all other components?
Make sure you use āgithubā and not āGitHubā.
I have had this happen to meā¦ it is case sensitive I guess and wonāt work with capital GitHub (very odd - probably need to submit an issue in the HACS repo if no one has already).
New Relase v1.4.3
Breaking Changes
Changes
Features
Bugfixes
- Fix for
returning No timetable route found
@scstraus Thanks for helping with this one
Hi, I have the checker error again
General Errors:
Iām not familiar with starting HA from command line and so Iām a little afraid of executing the update. Whatās your advice?
Everything points to the fact that the Checker Script is currently broken at least for custom components.
The actual functionality is not impacted. You can install it
good to know,thanks.
The checker script seems to have even some more issues. It claims a long log file containing the customizings without pointing on an issue.
publicTransportTimeTable works perfectly for me now!! Thanks!
Now I can toss out Waze, Google Maps, and GTFS, all of which give me troubles, as this does a better job than all of them combined!!
Thank you. Itās really great to hear when your work makes someone happy
will test your wonderful component/integrtion because of the really enthusiastic reports weāre reading here, so cool, thanks for this.
Will you allow for travel time using city names? Had that option in Waze before, but it stopped working, requiring gps long/lat instead of
origin: Berlin
destination: Brussels
would really make it a no brainer.
Unfortunately this is not supported by the API itself. It would be possible to combine two APIs to achieve that. Maybe sometime in the future
