Custom Component - HP Printer
@bar
After using the UI i can see the printer. I hope you will return the option to add printers via yaml and not only via UI as I have all my configuration via files.
I do have an issue with the color ink. The color level is 0 but I se N/A. Any idea why?
New version released
Integration:
Entities:
Didn’t plan to do that, why do you want it to be configured by YAML and not UI?
Can you please upload (in private) the debug data? (service will save the data in config folder) so I’ll be able to debug it
thanks
Thanks for the new version. I now receive some state information. :smiley:
Could you please tell me what the first sensor is? I guess it’s toner remaining. But what’s this “N/A N/A” and why is it -35%?
In my case it shows “inkCartridge” “Black” or “inkCartridge” “CyanMagentaYellow” followed by the amount of ink remaining in percentage.
Kinda looks like your cartridges are not being detected properly.
Can you please post the xml data from the printer?
Please see some posts back. I posted it yesterday.
This is a B/W laserjet. So there are no color cartridges.
I will need the following XML to understand the issue with the toner:
http://IP/DevMgmt/ConsumableConfigDyn.xml
Can you please post it?
thanks
Would You please check also mine? All my ink cartridges shows 0% which isn’t true. OfficeJet Pro 6970
          THIS DATA SUBJECT TO DISCLAIMER(S) INCLUDED WITH THE PRODUCT OF ORIGIN.
<ccdyn:ConsumableConfigDyn xmlns:dd="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/" xmlns:dd2="http://www.hp.com/schemas/imaging/con/dictionaries/2008/10/10" xmlns:ccdyn="http://www.hp.com/schemas/imaging/con/ledm/consumableconfigdyn/2007/11/19" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.hp.com/schemas/imaging/con/ledm/consumableconfigdyn/2007/11/19 ../schemas/ConsumableConfigDyn.xsd http://www.hp.com/schemas/imaging/con/dictionaries/1.0/ ../schemas/dd/DataDictionaryMasterLEDM.xsd">
<script/>
<dd:Version>
<dd:Revision>SVN-IPG-LEDM.290</dd:Revision>
<dd:Date>2010-06-02</dd:Date>
</dd:Version>
<ccdyn:ProductConsumableInfo>
<dd:NumOfUserReplaceableConsumables>4</dd:NumOfUserReplaceableConsumables>
<dd:NumOfNonUserReplaceableConsumables>1</dd:NumOfNonUserReplaceableConsumables>
<dd:AlignmentMode>semiAutomatic</dd:AlignmentMode>
<ccdyn:CartridgeChipInfo>disabled</ccdyn:CartridgeChipInfo>
<ccdyn:SupportedConsumables>
<ccdyn:SupportedConsumable>
<dd:ConsumableTypeEnum>ink</dd:ConsumableTypeEnum>
<dd:ConsumableLabelCode>M</dd:ConsumableLabelCode>
<ccdyn:SupportedConsumableInfo>
<dd:ConsumableSelectibilityNumber>903XL</dd:ConsumableSelectibilityNumber>
<dd:ConsumableUsageType>highVolume</dd:ConsumableUsageType>
</ccdyn:SupportedConsumableInfo>
<dd:ConsumableSelectibilityNumber>903</dd:ConsumableSelectibilityNumber>
<dd:ConsumableUsageType>everyday</dd:ConsumableUsageType>
</ccdyn:SupportedConsumable>
<dd:ConsumableLabelCode>C</dd:ConsumableLabelCode>
<dd:ConsumableLabelCode>Y</dd:ConsumableLabelCode>
<dd:ConsumableLabelCode>K</dd:ConsumableLabelCode>
<dd:ConsumableSelectibilityNumber>907XL</dd:ConsumableSelectibilityNumber>
</ccdyn:SupportedConsumables>
<dd:ConsumableSlotDirection>leftToRight</dd:ConsumableSlotDirection>
<dd:IK>743</dd:IK>
<ccdyn:SingleCartridgeMode>disabled</ccdyn:SingleCartridgeMode>
<ccdyn:GenuineHPSuppliesOnly>disabled</ccdyn:GenuineHPSuppliesOnly>
<dd:AntiTheftMode>disabled</dd:AntiTheftMode>
<ccdyn:MarkingAgentSubscriptionLevel>0</ccdyn:MarkingAgentSubscriptionLevel>
<ccdyn:RewardsRegistrationStatus>
<dd:State>enabled</dd:State>
<dd:OptedIn>false</dd:OptedIn>
<dd:AutoSendData>false</dd:AutoSendData>
<dd:PromptAutoSendData>false</dd:PromptAutoSendData>
</ccdyn:RewardsRegistrationStatus>
</ccdyn:ProductConsumableInfo>
<ccdyn:ConsumableInfo>
<dd:ConsumableContentType>markingAgent</dd:ConsumableContentType>
<dd:ConsumableFamilyName>KINGSTON</dd:ConsumableFamilyName>
<dd:ConsumableLabelCode>CMYK</dd:ConsumableLabelCode>
<dd:ConsumableLifeState>
<dd:ConsumableState>ok</dd:ConsumableState>
<dd:Brand>HP</dd:Brand>
<dd:IsTrial>false</dd:IsTrial>
</dd:ConsumableLifeState>
<dd:ConsumableReplaceabilityType>notReplaceable</dd:ConsumableReplaceabilityType>
<dd:ConsumableStation>0</dd:ConsumableStation>
<dd:ConsumableTypeEnum>printhead</dd:ConsumableTypeEnum>
<dd:Installation>
<dd:Date>2018-01-20</dd:Date>
</dd:Installation>
<ccdyn:ConsumablePersistentState>
<dd:PersistentMarkerState>nonHP</dd:PersistentMarkerState>
</ccdyn:ConsumablePersistentState>
</ccdyn:ConsumableInfo>
<dd:Capacity>
<dd:MaxCapacity>39</dd:MaxCapacity>
<dd:Unit>tenthsOfMilliliters</dd:Unit>
</dd:Capacity>
<ccdyn:ConsumableSubBrand>officejet</ccdyn:ConsumableSubBrand>
<ccdyn:ConsumableSegmentClass>class0</ccdyn:ConsumableSegmentClass>
<dd:ConsumableAcceptibilityUpgradability>notSupported</dd:ConsumableAcceptibilityUpgradability>
<dd:ConsumableFamilyName>PROHAN</dd:ConsumableFamilyName>
<dd:ConsumableKeyingDescriptor>smaller</dd:ConsumableKeyingDescriptor>
<dd:ConsumableState>newGenuineHP</dd:ConsumableState>
<dd:MeasuredQuantityState>veryLow</dd:MeasuredQuantityState>
<dd:IsRefilled>false</dd:IsRefilled>
<dd:IsSETUP>false</dd:IsSETUP>
<dd:IsSubscription>false</dd:IsSubscription>
<dd:ConsumableStateAvailableActions>
<dd:SupportedActions>
<dd:ConsumableStateAction>acknowledge</dd:ConsumableStateAction>
<dd:ConsumableStateAction>none</dd:ConsumableStateAction>
</dd:SupportedActions>
<dd:DefaultAction>acknowledge</dd:DefaultAction>
</dd:ConsumableStateAvailableActions>
<dd:ConsumableLevelMessagingStyle>dropCount</dd:ConsumableLevelMessagingStyle>
<ccdyn:ConsumableLowUseAlgorithm>everyday3</ccdyn:ConsumableLowUseAlgorithm>
<dd:ConsumablePercentageLevelRemaining>10</dd:ConsumablePercentageLevelRemaining>
<dd:ConsumableReplaceabilityType>userReplaceable</dd:ConsumableReplaceabilityType>
<dd:ConsumableSelectibilityNumber>903 SETUP H</dd:ConsumableSelectibilityNumber>
<dd:ConsumableStation>1</dd:ConsumableStation>
<dd:Installation>
<dd:Date>2018-01-15</dd:Date>
</dd:Installation>
<dd:Manufacturer>
<dd:Name>HP</dd:Name>
<dd:Date>2016-07-08</dd:Date>
</dd:Manufacturer>
<dd:SerialNumber>431537786</dd:SerialNumber>
<dd:RegionalCartridge>
<dd:RegionIdentifier>4</dd:RegionIdentifier>
</dd:RegionalCartridge>
<dd:ConsumableIcon>
<dd:Shape>Circle</dd:Shape>
<dd:Rotation>rotateZero</dd:Rotation>
<dd:FillColor>
<dd:Red>255</dd:Red>
<dd:Green>0</dd:Green>
<dd:Blue>255</dd:Blue>
</dd:FillColor>
<dd:OutlineColor>
</dd:OutlineColor>
<dd:BackGroundColor>
<dd:Green>255</dd:Green>
</dd:BackGroundColor>
<dd:RGBTextColor>
</dd:RGBTextColor>
<dd:Label>M</dd:Label>
</dd:ConsumableIcon>
<dd:Warranty>
<dd:ExpirationDate>2018-07-09</dd:ExpirationDate>
</dd:Warranty>
<ccdyn:ConsumableUniqueID>000000000000000044d5fdeed10b1e6c</ccdyn:ConsumableUniqueID>
<ccdyn:ConsumableRawData>
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
</ccdyn:ConsumableRawData>
<dd:Capacity>
<dd:MaxCapacity>35</dd:MaxCapacity>
</dd:Capacity>
<dd:ConsumableStation>2</dd:ConsumableStation>
<dd:Installation>
</dd:Installation>
<dd:Manufacturer>
</dd:Manufacturer>
<dd:SerialNumber>431369353</dd:SerialNumber>
<dd:ConsumableIcon>
<dd:FillColor>
<dd:Red>0</dd:Red>
</dd:FillColor>
<dd:OutlineColor>
<dd:Red>0</dd:Red>
</dd:OutlineColor>
<dd:RGBTextColor>
</dd:RGBTextColor>
<dd:Label>C</dd:Label>
<dd:Warranty>
</dd:Warranty>
<ccdyn:ConsumableUniqueID>000000000000000044d5fdee81012f05</ccdyn:ConsumableUniqueID>
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
<dd:Capacity>
<dd:MaxCapacity>34</dd:MaxCapacity>
</dd:Capacity>
<dd:ConsumableStation>3</dd:ConsumableStation>
<dd:Installation>
</dd:Installation>
<dd:Manufacturer>
<dd:Date>2016-07-15</dd:Date>
</dd:Manufacturer>
<dd:SerialNumber>432171426</dd:SerialNumber>
<dd:ConsumableIcon>
<dd:FillColor>
<dd:Blue>0</dd:Blue>
</dd:FillColor>
<dd:OutlineColor>
</dd:OutlineColor>
<dd:RGBTextColor>
<dd:Red>0</dd:Red>
</dd:RGBTextColor>
<dd:Label>Y</dd:Label>
<dd:Warranty>
<dd:ExpirationDate>2018-07-16</dd:ExpirationDate>
</dd:Warranty>
<ccdyn:ConsumableUniqueID>000000000000000044d5fdeea102142a</ccdyn:ConsumableUniqueID>
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
<dd:Capacity>
<dd:MaxCapacity>432</dd:MaxCapacity>
</dd:Capacity>
<dd:ConsumableKeyingDescriptor>large2</dd:ConsumableKeyingDescriptor>
<dd:ConsumableState>nonHP</dd:ConsumableState>
<dd:MeasuredQuantityState>low</dd:MeasuredQuantityState>
<dd:Brand>approvedOEM</dd:Brand>
<dd:ConsumableStateAction>continue</dd:ConsumableStateAction>
<dd:DefaultAction>continue</dd:DefaultAction>
<dd:ConsumablePercentageLevelRemaining>20</dd:ConsumablePercentageLevelRemaining>
<dd:ConsumableStation>4</dd:ConsumableStation>
<dd:Installation>
<dd:Date>2019-08-13</dd:Date>
</dd:Installation>
<dd:Manufacturer>
<dd:Name>NonHP</dd:Name>
<dd:Date>2018-06-11</dd:Date>
</dd:Manufacturer>
<dd:SerialNumber>561546319</dd:SerialNumber>
<dd:ConsumableIcon>
<dd:FillColor>
<dd:Red>0</dd:Red>
</dd:FillColor>
<dd:OutlineColor>
<dd:Red>0</dd:Red>
</dd:OutlineColor>
<dd:RGBTextColor>
</dd:RGBTextColor>
<dd:Label>K</dd:Label>
<ccdyn:ConsumableUniqueID>000000000000000044d5fdf05106451b</ccdyn:ConsumableUniqueID>
3600601e01630018885e2113c0040404130008c00002a0c050d2872400000000a0000945a082096000004000000000000000070044020000000100013282fc58000000000000000000000000000000000000000000000000000000000000000000490000000000000000000000000000000000000006ce1800030400000000a31000ffffffffffffffffffffffffffffffffff600000000000000011dec07923bd8619218c01b3b001000001133e0669002ebe92fcc4d954b19f01f4aae8cb95928c1bea00deca5de8fbd30a9c09178a6c0110000000000000000000000000000000000000000000000000000000000000000000000000000000000400030000
</ccdyn:ConsumableConfigDyn>
It seems that you have 10% for all color ink heads, for black 20%, will check it
Can you please provide the XML from http://IP/DevMgmt/(http://ip/DevMgmt/ConsumableConfigDyn.xml)ProductUsageDyn.xml?
thanks
Sorry. I misunderstood you.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<ccdyn:ConsumableConfigDyn xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:dd="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/" xmlns:ccdyn="http://www.hp.com/schemas/imaging/con/ledm/consumableconfigdyn/2007/11/19" xsi:schemaLocation="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/ dd/DataDictionaryMasterLEDM.xsd http://www.hp.com/schemas/imaging/con/ledm/consumableconfigdyn/2007/11/19 ConsumableConfigDyn.xsd">
<dd:Version>
<dd:Revision>SVN-IPG-LEDM.1103</dd:Revision>
</dd:Version>
<ccdyn:AtVeryLowSettings>
<ccdyn:ConsumableSetting>
</ccdyn:ConsumableSetting>
</ccdyn:AtVeryLowSettings>
<dd:StoreUsageData>disabled</dd:StoreUsageData>
<dd:CartridgeModelInformation>5e00</dd:CartridgeModelInformation>
<dd:CartridgeModelLife>0064</dd:CartridgeModelLife>
<dd:ConsumableLastUsedDate>1976-01-01</dd:ConsumableLastUsedDate>
<dd:Brand>clone</dd:Brand>
<dd:ConsumableLowThreshold>4</dd:ConsumableLowThreshold>
<dd:ConsumablePercentageLevelRemaining>0</dd:ConsumablePercentageLevelRemaining>
<dd:ConsumableSelectibilityNumber>44A</dd:ConsumableSelectibilityNumber>
<dd:ConsumableTypeEnum>toner</dd:ConsumableTypeEnum>
<dd:Installation>
<dd:Date>1976-01-01</dd:Date>
</dd:Installation>
<dd:Manufacturer>
<dd:Name>IQ </dd:Name>
<dd:Date>2033-10-10</dd:Date>
</dd:Manufacturer>
<dd:ProductNumber>CF244A</dd:ProductNumber>
<dd:SerialNumber>100730695</dd:SerialNumber>
<dd:ConsumableManufacturingSignature>03</dd:ConsumableManufacturingSignature>
<ccdyn:DataCollectionValid>false</ccdyn:DataCollectionValid>
<ccdyn:PreviousCartridgeData>
<dd:CartridgeModelLife>0000</dd:CartridgeModelLife>
<dd:Manufacturer>
<dd:Name>HP </dd:Name>
<dd:Date>2018-09-13</dd:Date>
</dd:Manufacturer>
<dd:SerialNumber>100794606</dd:SerialNumber>
<ccdyn:DrumLifeAtVeryLow>44</ccdyn:DrumLifeAtVeryLow>
<ccdyn:PageCountLetterAreaConvertedAtVeryLow>411</ccdyn:PageCountLetterAreaConvertedAtVeryLow>
<ccdyn:FormatterDesignatedRemainingToner>0</ccdyn:FormatterDesignatedRemainingToner>
<ccdyn:FormatterDesignatedPixelAtVeryLow>0</ccdyn:FormatterDesignatedPixelAtVeryLow>
<ccdyn:FormatterPagesAtOut>413</ccdyn:FormatterPagesAtOut>
</ccdyn:PreviousCartridgeData>
sorry for the link that wasn’t that clear, I found the issue, I took it from wrong XML, fixed it.
After update working as expected. Thank you.
@bar thanks!
It’s working.
My Photosmart 7520 doesn’t show correct information either. Let me know if you need anything else. Highly appreciated! Great integration.
Here’s the xml:
Edit: Removed the xml. I think something was just wrong with download or something, now works perfectly.
Excellent. Seems to work now. The toner IS empty. :slight_smile:
Hi
Good integration, but i have a pinter HP LaserJet 400 M401dne. He found me it ok but show only correct status and printed pages. No show me status of toner… Look on screen. Show NA NA and 0% but actual state toner is 50%.
What i must share you to add support full my printer with your integration ?
state
And my XML
Does anyone know why I keep getting this error message in my logs? I’ve gotten it with the older and newer version “[custom_components.hpprinter.HPDeviceData] Head type ink color mapping for pK not available”
