yeah, that makes sense. i havent made any changes to any entities, though, so im not sure. for some reason the dining table switch had a slightly different entity name, so i updated it to match what it should be. reloaded the integration and it worked! for like 2 minutes. then i had the same problem again.
looking at the logs i have a bunch of the same “unable to find entity” errors. i might remove the switch totally from hubitat and HA, reset the switch and pair it again, then share it back to home assistant. it feels like a communication issue between HA and HE but its not impacting every device for some reason so maybe that will start it fresh with the affected devices.
