[Custom Component] Instagram Fallower Counter
:memo: Description:
This integration adds a sensor that retrieves the number of Instagram followers for a specified user.
🤷‍♂ How it works?
Every 6 hours there is an API call to get instagram followers counter.
There is a 500 API Calls limit per month
:hammer_and_wrench: Installation
1.Add this repository to your HACS with the following button:
2.Install this integration with the follwing button:
Open your Home Assistant instance and start setting up a new integration.
:question:How to get token
  1. To get token you need to create an account on https://rapidapi.com/,
  2. Search for instagram scraper api Instagram Scraper API and press Subscribe for Basic
  3. Token is your x-rapidapi-key
    Token
:dart: Results
result
Repository:
I see it’s been a while since you’ve posted, but I just want to ask—has anyone had any luck getting this to work recently? Instagram’s API keeps changing, so I’m wondering if this still functions or if someone found a workaround with scraping or a different integration. Would love to get follower counts in my dashboard again.
Played around with a custom Instagram follower counter recently, and it’s fun to see numbers move in real-time. Some people use tools like famoid.com to give their follower count a small boost, which can make the counter look more active and attract real engagement.
