What makes things more confusing is that solar and grid seem to be calculating correctly but none of the circuits iotawatt is monitoring are being calculated correctly anymore. And on top of that two of the sensors that have stopped recording correctly in the energy dashboard arenāt even from the iotawatt integration
For the first time in almost 2 years since installing the IotaWatt I was forced to go to the garage and power cycle itā¦ I could ping it but not access the webui and it wasnāt feeding data to Home Assistant. I hope all this doesnāt mean that its dying.
Probably not dyingā¦ I know there was an issue recently with a specific firmware update (v2.0.8, IIRC) that negatively impacted some recently shipped units that contained a specific model of microSD memory card. This led the IoTaWatt team to revert all units back to the previous firmware as a safety precaution.
Inside an IoTaWatt is an off-the-shelf NodeMCU ESP8266 microcontroller, plugged into a socket on the mainboard. Should this ever fail, it is pretty easy to replace. Also, there is a microSD memory card which maintains the historical energy usage data. It is possible that this microSD memory card could wear out over time, although I am not aware of this being a common issue with the IoTaWatt.
Hopefully, your IoTaWatt will continue to behave well for many more years to come!
I know this has been discussed a couple times in this thread at least. I am needing to rename my āoutputsā since the IoTaWatt UI limits the characters. With two units I want to prepend the unit name onto it. I see a report of the HACS version being different but havenāt tried it. Do they show as sensors in that one that I can edit?
If anyone else is getting a warning about the component being disabled in 2023.3 it looks like you can fix it by changing line 16 in init.py to await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
I have opened a PR but no activity there for a couple of years
Can anyone help me with how to install this custom integration? Iām a bit lost.
The āofficialā HA IotaWatt integration is dead, so trying to find another way to integrate IotaWatt data into HA. Stumbled upon this custom option.
I can see this after adding the custom repository:
It ran for a day, then died and now the integration refuses to reload. Since thatās a different integration and OT for this thread, hereās the link on that. Seems I am not alone with this problem and there does not appear to be a solution for it:
After installing it in HACS you then need to go to Setting > Devices & Services > Add Integration > Look up IotaWatt (custom one) > follow the prompts.
Worth noting the thread you have referenced is a year old, Iām not aware of any recent issues with the core integration and itās still working fine for me. Might we worth checking your DNS settings.
I just had a quick look and the custom integration kinda seems abandoned. Before swapping to the core integration I was using rest sensors instead and that worked really well, Iāve even been thinking of going back to them as they seemed to respond quicker to changes in the sensor values.
Its also worth making sure the HA network can connect to the IoTaWatt through a browser, if you go to 192.168.0.74 while on the 192.168.0.x network what do you get?
Thanks. Someone else suggested REST API to me yesterday, I looked and it didnāt make much sense to me but this looks similar. They pointed me to this post:
Just so I understand how this work, this yaml goes inside the yaml.config file?
Are all the data channels accessible? e.g. energy accumulation, voltages, power factors etc?
Presumably if I change the IotaWatt settings, e.g. a swap some CTs around to measure something else and rename it, then I need to change the yaml code, is that right?
Maybe I try to get one data channel working and go from there.
