Deprecated - Custom Component Krisinformation (Sweden)
I’m working on a new version, but it’s not ready yet.
This is a work in progress and I would appreciate having a couple of users testing it and reporting back!
stability-wip
Version maintained
maintainer
# sensor.krisinformation
Component to get Krisinformation for Home Assistant.
Will get all messages from Krisinformations api in a set radius from your coordinates.
If one of the fetched messages is an alert as opposed to news, the state of the sensor will be “Alert”. The sensor contains all fetched messages as objects.
Use together with custom card for Lovelace:
This component is supported by Custom updater and Tracker card.
## Installation:
1. Install this component by copying to your /custom_components/sensor/ folder.
2. Add the code to your configuration.yaml using the config options below.
3. You will need to restart after installation for the component to start working.
* If you’re having issues, ask for help on the forums or post an issue.
Configuration variables:
key | type | description
platform (Required) | string | krisinformation
latitude (Required) | sring | The latitude of the position from which the sensor should look for messages.
longitude (Required) | string | The longitude of the position from which the sensor should look for messages.
name (Optional) | string | Custom name for the sensor. Default krisinformation
radius (Optional) | number | The radius in km from your position that the sensor should look for messages. Default 50
Example configuration.yaml:
yaml</s> <s>sensor:</s> <s> - platform: krisinformation</s> <s> name: Krisinformation Stockholm</s> <s> latitude: !secret lat_coord</s> <s> longitude: !secret long_coord</s> <s> radius: 100</s> <s>
## Usage
Example automation for getting a notification when the sensor has an alert:
yaml</s> <s>automation:</s> <s> - alias: 'Krisinformation Alert'</s> <s> initial_state: 'on'</s> <s> trigger:</s> <s> platform: state</s> <s> entity_id: sensor.krisinformation</s> <s> to: "Alert"</s> <s> action:</s> <s> - service: notify.my_phone</s> <s> data_template:</s> <s> message: ></s> <s> {{states.sensor.krisinformation_stockholm.attributes.messages[0].Headline}} - {{states.sensor.krisinformation_stockholm.attributes.messages[0].Message}} {{states.sensor.krisinformation_stockholm.attributes.messages[0].Web}}</s> <s>
https://github.com/isabellaalstrom/sensor.krisinformation
Great job :+1:
Do you know how much info that is gathered from this channels?
https://cert.se/
https://www.msb.se/
Great work!
You could default lat/long to home location?
Krisinformation.se is MSB:s site.
I don’t know anything about cert.se unfortunately.
Thanks! And yes, I plan to do that as soon as I get the time. I have opened an issue on that myself. :smiley:
It warned about some cert stuff right before christmas. (I did a component a couple of weeks ago for this, but this one is much better)
I found a bug, so hold on a bit!
Bug fixed, version 0.0.2 out now!
Well done @teachingbirds :ok_hand:
A few more bugs squashed, so now it’s on 0.0.4. I’m working on getting it in custom updater and tracker card for those who use that, then this process will be easier.
Available in custom updater now: https://github.com/custom-components/custom_updater
Made a quick custom card for Lovelace to display the information since it’s not that easy to see it otherwise: https://github.com/isabellaalstrom/krisinfo-card
The card is now also available in custom updater.
I think I have a problem with the sensor. Its the first message I got from the sensor but it does not seem to display correct. Message is [object Object]
krisinfo
It’s a list of objects. Look at the examples in the repo to see how to get the info from object.
I get this error in the log when trying to add the card:
Uncaught TypeError: Cannot read property 'attributes' of undefined
What can be wrong? The sensor seems to work ok.
Made sure you have the right sensor defined in the card?
v 0.0.9 is released.
With the latest releases you now don’t have to configure coords if you want the same ones as in your base configuration for Hass. You can also make a sensor for nation wide alerts, with the new option “country”.
You can also specify county (län) to get more accurate alerts for your whole county, despite setting a lower radius.
After updating Homeassistant to 0.89.0, I get no sensors to work. Neither “krisinformation”. When I comment out platform krisinformation, all sensors work again. What could be the problem?
