[custom component] Medtronic Carelink Integration
Hey. I made this for my wife so she can check here glucose levels on here smartwatch. Maybe there are more people with diabetes, a medtronic pump and a running Home Assistant server in their house who would like to try it out?
All feedback is welcome. I’m a long time Home Assitant user but it’s my first custom component so I’m pretty new to the contribution game.
Thank you so much! Going to take a look at this, maybe make a custom card to display it. Been wanting to make this for a long time so thank you again!
This is fantastic!
I’d really love to get this integration up and running in my HA setup. As a type 1 diabetic for the past 43 years it would be awesome to be able to have access to my levels trhough a card. I have attemtped to install as per the instructions, but can not get past the integration log in screen in HA. I believe that this is because MFA is now compulsory on all accounts:
Minimed
The code is coming to my email account from Minimed when I hit submit, but there is no way to validate this in the integration. Is this currently being looked at?
It’s a know limitation that 2FA isn’t working in this integration. For now you can use a Carelink Care Partner account where the 2FA is not mandatory yet.
The implementation of 2FA will take a lot of time I don’t have at the moment. I anyone wants to look at it I’m glad to help where I can.
I made following/partner account and got it linked to main carelink account. I logged in with newly created partner account and found the token + country code. Also added patient ID of main carelink account. Trying several times, but everytime i get “Invalid authentication” error. Any hints how to get forward? Thanks!
EDIT: Authentication was successful after data was send in, so i can confirm that this works now!
This add-on looks great! I installed the add-on, but am stuck at the login. I cannot get the login script running on my Windows pc. I know how to run python on my Rpi, but have no idea how to run it on my pc. It doesn’t run on the cli.
Any other options to obtain the codes?
In the meantime I progressed. Installed Python, the necesary packages and Firefox. Now I get the error “No module named ‘blinker._saferef’”. Google doesn’t help me out on this one.
Im currently having same problem - but did not have this problem last time i ran the script
Hey - just got this setup in US. Anyone have some cards they can share? Want to start setting up some monitoring / alerts potentially to supplement the current app
need to install blinker pip install blinker==1.7.0
first google: Wire Mode: `No module named 'blinker._saferef'` if installing `selenium-wire` alone · Issue #2782 · seleniumbase/SeleniumBase · GitHub
I made a Carelink Follower account.
I ran the script on my PC, logged in and generated the logindata.json.
I then copied the file in custom_components/carelink.
When the configuration popup appeared I only added the pacient ID with the main account username that my Carelink Follower is linked to.
My issue is that I do not see any values. ALL of them are Unknown.
Thank you so much for creating this custom component. It will help me keep track of my father’s diabetes and be able to keep records and discuss issues with our doctor. With my father getting older and getting dementia he is no longer able to keep track of all of it. This helps me and my mother get more grasp on his blood sugar levels and hopefully be able to intervene when needed.
The main one for us will be alerts, if the sensor is due to expire whilst we sleep, no more sensor changes at 3am!
Dear all, I’m totally new on HA. I already build / adapt my dashboard, installed and configured some custom components.
As we are 3 T1D people at home, I’m trying to make one page to display our 3 BG values. I’m a bit confused to configure this carelink component.
My HA is runnning on a raspberry, and I don’t understand how to and where I’ve to execute the python script in order to connect into carelink with the carelink follower account.
PS: I’ll have to display 2 medtronic 780g pumps and one Omnipod/dexcom G6 (this one is working)
Thanks by advance. And sorry for my request, I’m pretty sure it’s easy but, after 2 days, still blocked at this step :cry:
I finally succeeded to connect my carelink account and I can now see the pump of my son.
Now, I would like to “duplicate” this integration to display my own pump.
Is there a way to duplicate one integration to display another insulin pump?
Thanks by advance
I think that’s a dummy question. But what are Conduit battery level and other Conduit sensors???
For sure, I know the pump battery level and sensor battery level. But I’ve absolutely no idea about the “conduit”…
Hi! Due to the new authentification method built by Medtronic, I had to remove both custom integrations and rebuild them from scratch. I downlaoded 2 times the carelink from hacs, built new version of both logindata.json and updated the following files of the carelink2 integration (files manifest.json & const.py in order to update the name / domain from “carelink” to “carelink2” and the file api.py (in order to read the file "custom_components/carelink2/logindata.json)
After restarting home assistant, when I configure both custom integrations (carelink & carelink2) without any issue, all the values coming from both integrations are displaying the data from the first insulin pump only.
I don’t understand what I"m doing wrong. Any idea?
Thanks by advance
Hello @paulobenoit, I've just installed this and found that I needed to make a separate read-only follower account without MFA in it. That did the trick!
To @Yo.han : Thank you very much! You helped me make my wife happy as well! :smiley: Love this!
