Hey
I have created a custom component for getting your Office 365 Outlook calendar events directly via the Microsoft Graph api.
I noticed that somebody already found it on this forum and linked to the github project, but i thought i might as well create a post announcing this.
Until now the only solution i have found for getting calendar events from O365 into Home Assistant, have been sharing the calendar with a Google calendar and then importing that calendar.
Now you can authenticate directly with O365, and get the info directly without having to proxy it through google first.
I myself am using this to have node-red access my work calendar and then update a binary switch on home assistant setting whether it’s a work day or not. This switch then in turns powers some other automations that depends on whether i need to work or not.
The sensor is available as an integration in HACS’ default repo list
Project repo, see the readme for the installation/configuration guide
If you run into any issues, or have a feature request, please create a GitHub Issue
