I am seeing the exact same thing. I first installed the integration yesterday, and I was already on Intellicenter 1.064 prior to trying the integration. The integration discovers everything just fine, but it drops the connection after 20 seconds, waits 30 seconds to reconnect and then repeats that cycle over and over.
Thank you for creating this! I’ve got it installed and it works great.
One question - is there support for Groups? I’ve got a few water features that appear as Groups under the pentair app - and I don’t see entities created for them.
Ok. Well that nixes it. I’m looking to replace just my pump (or pump motor). Not buy an overpriced bespoke controller. I think I’ll stick with Century Green. Someone wrote an integration for that. Too bad. I found a 3HP IntelliFlow refurb in my area for $300.
Hi All - recently the integration lost connection with the pool controller and is throwing these errors. i’m seeing others in the GitHub repo saying the same. anyone else? any fixes?
Has anyone else updated their Intellicenter firmware to Firmware IC: 2.006 ICWEB:2022-10-07 2.006 and able to successfully connect? Any tweaks you made to your configuration? Thanks for the help!
I have not as a I have a heat pump, but I did create a utility meter helper for my pump wattage that shows me how much energy the pump has been using through the month.
I just installed the integration. My IntelliCenter is still on Firmware: IC: 1.064 , ICWEB:2021-10-19 1.007.
No issues whatsoever. Very happy and based on your queries, will probably stay on 1.064.
