QuestDB state storage (QSS) custom component for Home Assistant
QSS makes it possible to transfer state information of the Home Assistant entities simply and efficiently via InfluxDB Line Protocol into a QuestDB for long-term storage and later analysis.
What ist QuestDB?
QuestDB is the new kid on the block of time series optimised databases and claims to be the fastest open source time series database currently available.
QuestDB offers high throughput ingestion and real-time SQL queries for applications in a wide range of use cases. It has a tiny memory footprint and combines the best of different worlds by supporting record entry via the fast and simple InfluxDB Line protocol, while offering great compatibility for common SQL queries (PostgresSQL).
If you want to learn more about the possibilities of QuestDB, have a look at the documentation or this great Youtube video by Code to the Moon.
QSS itself is not a replacement for the recorder component integrated in Home Assistant, but merely offers an alternative for long-term data storage.
Installation
Precondition
- Make sure that your QuestDB instance is up and running.
- Possible installation methods for QuestDB can be found in the ‘Get started’ section of the documentation.
- Apart from that, you do not need to take any further precautions at present. QSS automatically creates a table named
qssin which it stores the data.
Installation of the QSS component:
Manual:
- Copy the
qssfolder in thecustom_componentsfolder of this repository into thecustom_componentsfolder of your Home Assistant installation.
Automatic:
- Just search for “qss” and install the integration via HACS.
configuration.yaml
- Add an entry to your Home Assistant
configuration.yamlthat might look like this::
qss:
host: "192.168.178.3"
port: 9009
include:
domains:
- "sensor"
entities:
- "person.john_doe"
Configuration
qss:
(map)(Required)
Enables the qss integration. Only allowed once.
host:
(string)(Required)
The URL or IP Address that points to your QuestDB database.
port:
(int)(Required)
The port to the InfluxDB line protocol of your QuestDB installation. This is normally 9009 by default.
exclude:
(map)(Optional)
Configure which integrations should be excluded from recordings.
domains:
(List[str])(Optional)
The list of domains to be excluded from recordings.
entities:
The list of entity ids to be excluded from recordings.
entity_globs:
Exclude all entities matching a listed pattern from recordings (e.g., `sensor.weather_*`).
include:
(map)(Optional)
Configure which integrations should be included in recordings. If set, all other entities will not be recorded.
domains:
The list of domains to be included in the recordings.
entities:
The list of entity ids to be included in the recordings.
entity_globs:
Include all entities matching a listed pattern from recordings (e.g., `sensor.weather_*`).
Details
The data is stored in a QuestDB table named qss, which has the following structure:
| Column name: | entity_id | state | attributes | timestamps |
| Type: | symbol | string | string | timestamps |
Credits
- First of all, thanks to all the contributors to the great QuestDB project. Without their work, this custom component would never have been created.
- QSS was largely inspired by and based on LTSS (Long Time State Storage) by freol35241. Many thanks to freol35241 for his great work!
Disclaimer
- QSS is not an official extension of the QuestDB project and is not directly related to it.
- No liability is accepted for any loss of data that may occur through the use of QSS. Use at your own risk!
