Custom component requirement not installed
I try to fix the custom component for Fujitsu ACs:
As a requirement, I published the module pyfujitseu on PyPi. During startup of Home Assistant Core on docker, I get the following error message:
2020-05-25 14:07:12 ERROR (MainThread) [homeassistant.config] Platform error: climate
  File "/usr/src/homeassistant/homeassistant/config.py", line 777, in async_process_component_config
    platform = p_integration.get_platform(domain)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 273, in get_platform
    f"{self.pkg_path}.{platform_name}"
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/fujitsu_general_heatpump/climate.py", line 7, in <module>
    import pyfujitseu
ModuleNotFoundError: No module named 'pyfujitseu'
If I bash into the container and do
pip install pyfujitseu
The component is working properly.
How can I solve this?
You’ll need to add the required lib in the manifest of the integration
Hi @Pippyn, Thanks for your answer.
I have a manifest file. See:
Your requirements look correct, but your domain is not. The domain should be a string containing underscores like your name. Integration Manifest | Home Assistant Developer Docs
I’m not sure if that is related to your requirement not getting installed or not.
Hey @fahr, thanks for your answer. Unfortunately, my requirement is still not resolved.
I’m stumped, your manifest.json looks correct to me.
I’m also interested in this issue.
I installed package inside HA ssh using:
python3 -m pip install pyfujitseu
and get the same error:
Platform error climate.fujitsu_general_heatpump - No module named 'pyfujitseu'
I’ve just seen that HA is running python3.7 and “pip install” do the installation on python3.8 libs so I guess I should install on another container.
Do you know where to install pyfujitseu?
I solved it installing inside homeassistant container that is not the same as doing ssh inside HA:
docker exec -it homeassistant /bin/bash
@philwilldo I think you are not importing the correct way: I see 3 import-statements in your climate.py.
Try this instead, write instead of import pyfujitseu:
from pyfujitseu.api import Api as fgapi
from pyfujitseu.splitAC import splitAC
Remove the other 2 import-statement lower in the code.
And then write fgapi instead of fgapi.Api, and splitAC instead of splitAC.splitAC in climate.py.
I’ve added a PR that makes this change (as well as fixing the created directory name).
thanks, @esteele
