I sure I’m doing something wrong here, but I’m trying to contribute a change to a library used by an integration custom component and I’m having a devil of a time when attempting to load that requirement from my forked GitHub repo. The docs seem to indicate it’s possible, but when using the format shown here Custom requirements during development & testing I get the following exception showing up in the logs
2022-12-05 20:52:50.866 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration openevse which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-05 20:53:49.479 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/pkg_resources/_vendor/packaging/requirements.py", line 102, in __init__
req = REQUIREMENT.parseString(requirement_string)
File "/usr/local/lib/python3.10/site-packages/pkg_resources/_vendor/pyparsing/core.py", line 1141, in parse_string
raise exc.with_traceback(None)
pkg_resources._vendor.pyparsing.exceptions.ParseException: Expected string_end, found '+' (at char 3), (line:1, col:4)
It goes on a bit with additional characters that it doesn’t seem to like as it moves through the string.
The requirements entry I’m using is
git+https://github.com/david81/python-openevse-http.git@session-usage
Has the format for specifying requirements during dev changed?
This is on a fresh docker instance setup specifically for dev work on this component.
