Hi there,
I’m trying to build a custom component using a RESTful Sensor to collect Data from a JSON API.
My Problem is, that I do not understand, how to map the Data to Home Assistant.
That’s what I have so far:
class JSONRestSensor(Entity):
"""Implementation of a REST sensor."""
def __init__(self, hass, rest, name, unit_of_measurement, value_template):
"""Initialize the REST sensor."""
self._hass = hass
self.rest = rest
self._name = name
self._attributes = {}
self._state = STATE_UNKNOWN
self._unit_of_measurement = unit_of_measurement
self._value_template = value_template
self.update()
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def unit_of_measurement(self):
"""Return the unit the value is expressed in."""
return self._unit_of_measurement
@property
def state(self):
"""Return the state of the device."""
return self._state
def update(self):
"""Get the latest data from REST API and update the state."""
self.rest.update()
value = self.rest.data
if value is None:
value = STATE_UNKNOWN
self._state = value
""" Parse the return text as JSON and save the json as an attribute. """
try:
attributes = json.loads(value)
if isinstance(attributes["Data"]["Inputs"], list):
_LOGGER.debug("Parsed attributes form a list. Adding it as 'list'")
self._attributes["list"] = attributes["Data"]["Inputs"]
"""Create a single sensor for every transmitted value"""
"""collect them in a list to create a group containing them later"""
sensor_list = []
"""Iterate over all sensors"""
for sensorobj in self._attributes["list"]:
_sensor = sensorobj
_LOGGER.debug("Sensor found %s" % _sensor["Number"])
"""differentiate between analog (value) and digital (on/off) sensors, also skip time value"""
if _sensor["AD"] == "A":
entity_id = "sensor.uvr16x2_data_logger_%s" % (_sensor["Number"])
_sensor["icon"] = "mdi:thermometer"
elif _sensor["AD"] == "D":
entity_id = "binary_sensor.uvr16x2_data_logger_%s" % (
_sensor["Number"]
elif "time" in _sensor:
continue
else:
"""do the adding"""
self._hass.states.set(entity_id, _sensor["Value"]["Value"], _sensor)
sensor_list.append(entity_id)
"group.uvrlog_data_logger",
"Running",
"entity_id": sensor_list,
"friendly_name": self._name,
"icon": "mdi:radiator",
"""Set yourself as hidden"""
self._attributes["hidden"] = "true"
except json.JSONDecodeError:
pass
@property
def state_attributes(self):
"""Return the attributes of the entity.
Provide the parsed JSON data (if any).
return self._attributes
class JSONRestData(object):
"""Class for handling the data retrieval."""
def __init__(self, method, resource, auth, headers, data, verify_ssl):
"""Initialize the data object."""
self._request = requests.Request(
method, resource, headers=headers, auth=auth, data=data
).prepare()
self._verify_ssl = verify_ssl
self.data = None
def update(self):
"""Get the latest data from REST service with provided method."""
try:
with requests.Session() as sess:
response = sess.send(self._request, timeout=10, verify=self._verify_ssl)
self.data = response.text
except requests.exceptions.RequestException:
_LOGGER.error("Error fetching data: %s", self._request)
self.data = None
This is my Data:
"Data": {
"Inputs": [
"Number": 0,
"Description": "T.Heizkreis VL",
"AD": "A",
"Value": {
"Value": 39.8,
"Unit": "°C"
"Number": 1,
"Description": "T.Kessel VL",
"AD": "A",
"Value": {
"Value": 70.1,
"Unit": "°C"
"Number": 2,
"Description": "T.Solar RL",
"AD": "A",
"Value": {
"Value": 49,
"Unit": "°C"
"Number": 3,
"AD": "A",
"Value": {
"Value": 32.5,
"Unit": "°C"
Now, how do I tell Home Assistant that friendly_name is Description from JSON Data, value is [Value][Value] an so on?
I hope my question is understandable andyou can help.
