Hi
As latest firmware is closing down the local API over http, I created an integration based on the supported Modbus TCP communication protocol.
It’s my first home-assistant integration, so feedback very welcome:)
Config through Integrations UI.
Hi
Nice, even with ui configuration. Is it possible to implant it in core?
I’m sorry but I have same problems… I left an issue on github.
FV with solaredge SE4000H + LGchem battery + solaredge smartmeter
connected to my network through Ethernet … modbus activated
My value coming from the meter are always 0
My AC Power value during the night is showing the home consumption, during the day FV production… quite confusing…
no other values are coming as import/export/etc.etc.
After installation is it possible to lower the default interval time of 30 seconds? Or do I need to remove and install the integration again?
And is 5 seconds also a good value? Using a Odroid N2+ for HA.
