This tool can help you manage your custom_components for Home Assistant.
This will only manage the .py files for you under custom_components/, you still need to manually add/remove entries in configuration.yaml.
Platforms can only be managed if they the remote repository are using the new embedded structure that was introduced in 0.86.0
Home Assistant version 0.86 or newer is required to use this.
Why docker container?
This is a bundle that contains 3 parts to operate:
This looks pretty awesome. Shame I don’t use Docker. Can this work on a non Docker system if I was to install Docker just for this? I have HA running in a virtual environment under Raspbian on my Pi3.
ludeeus, I just tried install ludeus/custom-component-store with docker but the image is not found. Did something change and this is not available any longer?
