Hiya @pedro96 Hope you are OK and having a great week Sorry, I promised an update on my installation, but have been hampered (as we all are) but life/work etc. I had a new pack of Tapo L530 bulbs, which would have finished off my house, from normal, to all smart bulbs I tried for over a week to get one of the bulbs linking up, and seemed to manage to mess up my HA in the process X-) (Totally my fault/problem) but just in case anyone else is reading on - I couldnāt get the TAPO Controller integration to work (please read on to see why!) and so I tried to uninstall and re-install it - strangely, even though Iāve been in the business for 27 years now, I found trying to remove an integration to be somewhat of a mystic art , and probably ended up removing all the wrong things - SO the lesson of the start of my paragraph, is don;t just try and remove this integration, as it does work!, and if you are careless like me, you get to reinstall HA again
Onto the main reason for my update - firstly, again thanks for writing this awesome integration I really like the output from the Tapo bulbs, so it would be a shame to have to migrate to another bulb type (not including the cost of course!)
The actual reason the new bulb didnāt work, was a bit more obvious when I took the initiative to look in the right/obvious place
The new bulb is not just new firmware, but new hardware, compared to all my other bulbs. The new one is
- Model āTapo L530ā
- Hardware Version ā2.0ā
- Firmware Version ā1.0.6 Build 211029 Rel. 105823ā
The old one is :
- Model āTapo L530 Seriesā
- Hardware Version ā1.0ā
- Firmware Version ā1.1.9ā
So I am pretty sure there must be a variation of command set , or something slightly different on the newer hardware/firmware.
It does integrate via the UI, and Iām pretty sure it comes up as a match to the L530 , as you get a colour picker chart, when selecting the bulb in HA.
When controlling the bulb, it allows you to turn on and off, and the slider works from cool to warm incrementally all ok.
If you try and change the brightness, you get an error popping up in the bottom left of the screen in HA, saying: āfailed to call service light/tun_on. Index out of rangeā
If you try and use the colour picker, you get a message saying āfailed to call service light/turn_on, None-Typeā (and then something I havenāt caught yet, as it goes too quick.
After trying to use these a few times, it seems to crash the bulb, and it becomes unresponsive. Sometimes it will come back online in a few minutes, otherwise you can off/on it from the mobileTapo app (Iāve not blocked internet access , while migrating/setting up) , or powering it off/on works too.
if you have some pointers to decrypt the traffic, I can probably setup a port mirror, and capture the app talking to the new hardware bulb, and pass on the info to you, in case this is indeed different in hardware 2.0 to hardware 1.0
Sorry for the long rambling message, hope this helps, and thanks in advance if you have time to investigate this new model too
Cheers, pi
