Do you have card-mod installed from HACS?
The “Playing” text should be overlaid on the bar card, which you need card-mod for (among other things).
thanks for the nudge, I needed to re-download card-mod for whatever reason. all good now
i will look into this error . thanks for letting me know
Please Checkout the Beta Released and let me know if this sorts your issues and or if you get any errors.
Hi everyone,
I’m looking to add a logo or image in Home Assistant for my Tautulli Active Streams integration. I’d really appreciate help from anyone skilled in graphic design to create something that stands out and fits well with the aesthetics of Plex, Tautulli, and Home Assistant.
If you’re interested in collaborating or have any ideas, please send me a PM/DM or reply here.
Thanks for your support!
Removed everything and re-added 2.2.0-beta.2. Still works great with http access. Still errors out on the https install, though with different phraseology this time. I’m running HA Core 2025.2.4 for the record.
2025-02-18 22:57:23.645 INFO (MainThread) [homeassistant.setup] Setting up tautulli_active_streams
2025-02-18 22:57:34.646 INFO (MainThread) [homeassistant.components.sensor] Setting up tautulli_active_streams.sensor
2025-02-18 22:57:34.647 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.plex_session_2_tautulli
2025-02-18 22:57:34.648 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.plex_session_3_tautulli
2025-02-18 22:57:34.648 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.plex_session_4_tautulli
2025-02-18 22:57:34.648 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.plex_session_5_tautulli
2025-02-18 22:57:34.649 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.plex_session_6_tautulli
2025-02-18 22:57:34.649 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.stream_count
2025-02-18 22:57:34.649 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.stream_count_direct_play
2025-02-18 22:57:34.650 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.stream_count_direct_stream
2025-02-18 22:57:34.650 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.stream_count_transcode
2025-02-18 22:57:34.650 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.total_bandwidth
2025-02-18 22:57:34.651 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.lan_bandwidth
2025-02-18 22:57:34.651 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.wan_bandwidth
2025-02-18 22:57:42.826 ERROR (MainThread) [custom_components.tautulli_active_streams] Setup of sensor platforms was cancelled
2025-02-18 22:57:44.647 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform tautulli_active_streams is taking over 10 seconds.
2025-02-18 22:57:45.645 INFO (MainThread) [homeassistant.helpers.entity_registry] Registered new sensor.tautulli_active_streams entity: sensor.plex_session_1_tautulli
2025-02-18 22:57:45.654 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setups for integration tautulli_active_streams with title: Tautulli Active Streams and entry_id: 01JMCNJS1X2G1VZWP530E1K2XB, during setup without awaiting async_forward_entry_setups, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1, please report this issue
Stack (most recent call last):
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 707, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 678, in run_forever
self._run_once()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2033, in _run_once
handle._run()
File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2289, in async_forward_entry_setups
_report_non_awaited_platform_forwards(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1193, in _report_non_awaited_platform_forwards
report_usage(
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 234, in report_usage
_LOGGER.warning(msg, stack_info=True)
Check that your using the latest version and latest card updated
Wow! Looks great and works good so far…! Uhmm is it possible to get 2 tautulli instances into this ? ![]()
thank you. please give the github a star ![]()
this will be a future update but currently working on some other improvements
i am using the latest. issues seems to be with mobile devices. seems to work fine on PC
unfortuantly this will be an issue on your end. try redownloading some recent cards/ integrations from hacs. something will be causing this issue.
Wanted to pass this project on for everyone these two integrations/cards pretty much go hand in hand. there might be some interesting ways to combine the two.
Checkout the latest Release and let me know what you think?
is there any issues or improvements you see?
have you got any Automations that we could add to our GitHub?
Lets keep this improving!
Just wanted to thank you for this amazing work! Much appreciated and I might admit I do not use the Tautuli app that much now thanks to the integration into HA!
Thank you.
with the help of everyone this will only get better. do you use any automations with this ? would like to know other peoples use case other than the custom card
Hi there. You should only past the card once.
This creates a card for each session
i seemed to have been able to fix it. but whenever i close the app and reopen it. it fails to get the picture
use the latest card version and integration update. let me know how you get on and if any issues give some more details
thanks
Is there a way to filter this for local network or certain users? For example, I don’t need to list what all my external plex users are watching on my wall mounted tablet. Just what is streaming inside my home.
