[Custom Component] TP-Link Router Integration
v1.6.0 Released
Changelog
  • Added Support for TP-link C1200 by @swwgames
  • Added Archer AX72 V1 to list of supported Hardware
If you tried to use this integration and it didn’t work for you - please try it again. As TP-link Archer C1200 v2.0 support with different login process was added - this allows to support other routers
I have an AX10000. I will try to get you an XHR dump from it
Any news with possibility to block device connected to wifi? Like a parental control?
My router doesnt allow to block devices. So I cannot add this feature
Would be great if you can add it
v1.7.0 Released
Changelog
  • Added Archer MR200 v5.3 support
As TP-link Archer MR200 has different api - this allows to support other similar routers.
Unfortunately I don´t know how.
v1.8.0 Released
Changelog
v1.9.0 Released
Changelog
  • Added Archer AX55 v1.0, Archer AX75 V1 and Archer AXE75 V1 supports
what type do you have? It it is under parental control you need add ay least one rule for some devices and than you can pause internet for that device.
What do you mean about type?
v1.10.0 Released
Changelog
  • Added Support for Wifi 6G
  • Added enable/disable switches for 6Ghz WiFi for guest, main and IoT wifi networks
My is archer c6
I use Archer MR200 v5.3 right now. It has completely different api with Archer C6.
Hi, I need help, maybe because I’m noob… :frowning:
As I try to use the Web Encrypted Password way to login I get this error in my console:
document.getElementById("login-password").value;
VM1055:1 Uncaught TypeError: Cannot read properties of null (reading 'value')
    at <anonymous>:1:42
and nothing appears… Can you help me? My router is a tp-link archer c6 in 192.168.0.75
Thank you
I tried this with my TP-Link RE505X but it doesn’t work. Maybe because it’s a repeater? I get “No devices or entities”
What is your router hardware version?
Have you checked what router responses by api?
Firmware Version:
1.13.2 Build 230824 Rel.75032n(4555)
Hardware Version:
Archer C6 4.0
Your router is not supported yet.
