Home Assistant component for complete TP-Link router administration with sensors, button reboot, switches and device tracking.
With configuration via GUI
Components
Events
tplink_router_new_device: Fired when a new device appears in your network
tplink_router_device_offline: Fired when a device becomes offline
tplink_router_device_online: Fired when a device becomes online
Switches
Router Reboot
2.4Ghz main wifi Enable/Disable
5Ghz main wifi Enable/Disable
6Ghz main wifi Enable/Disable
2.4Ghz guest wifi Enable/Disable
5Ghz guest wifi Enable/Disable
6Ghz guest wifi Enable/Disable
2.4Ghz IoT wifi network Enable/Disable
5Ghz IoT wifi network Enable/Disable
6Ghz IoT wifi network Enable/Disable
Sensors
Total amount of wired clients
Total amount of IoT clients
Total amount of main wifi clients
Total amount of guest wifi clients
Total amount of all connected clients
CPU used
Memory used
Device Tracker
Track clients by MAC address across 2.4Ghz, 5Ghz, 6Ghz guest and main wifi with connection information
Supported routers
Fully tested Hardware Versions
Archer A7 V5
Archer AX10 v1.0
Archer AX12 v1.0
Archer AX20 v1.0
Archer AX21 v1.20
Archer AX23 v1.0
Archer AX50 v1.0
Archer AX55 v1.0
Archer AX55 V1.60
Archer AX72 V1
Archer AX73 V1
Archer AX75 V1
Archer AXE75 V1
Archer AX3000 V1
Archer AX6000 V1
Archer AX11000 V1
Archer C1200 v2.0 (You need to use web encrypted password )
Archer C6 v2.0
Archer C6 v3.0
Archer C6U v1.0
Archer C7 v5.0
Archer MR200 v5
Archer MR200 v5.3
Archer MR600 v1
Archer MR600 v3
Archer VR900v
Deco M4 2.0
Deco M4R 2.0
Deco M5
Deco M9 Pro
Deco P7
Deco X20
Deco X60
Deco X90
Deco XE75 2.0
TL-WA3001 v1.0
TL-MR105
TL-MR6400 v5
TL-MR6400 v5.3
Not fully tested Hardware Versions
AD7200 V2
Archer A6 (V2 and V3)
Archer A9 V6
Archer A10 (V1 and V2)
Archer A20 (V1, V3)
Archer C7 V4
Archer C8 (V3 and V4)
Archer C9 (V4 and V5)
Archer C59 V2
Archer C90 V6
Archer C900 V1
Archer C1200 V3
Archer C1900 V2
Archer C2300 (V1, V2)
Archer C4000 (V2 and V3)
Archer C5400 V2
Archer C5400X V1
TD-W9960 v1
TL-WR1043N V5
Please let me know if you have tested integration with one of this or other model.
TP-Link Archer AX10 support confirmed
I have made a research.
These routers also should be supported, but I can’t test the integration completely with them.
If you have one of them, could you test this component please and let me know?
Models:
AD7200 V2
Archer A7 V5
Archer A9 V6
Archer A20 (V1, V3)
Archer AX50 V1
Archer AX3000 (V1, V2)
Archer AX6000 V1
Archer C6 V4
Archer C7 (V4 and V5)
Archer C59 V2
Archer C90 V6
Archer C900 V1
Archer C1200 (V2, V3)
Archer C1900 V2
Archer C5400 V2
Archer C5400X V1
TL-WR1043N V5
jjusko
(Jozef Jusko)
December 4, 2023, 10:41am
4
Is it possible to allow block device connected to wifi? Or can you add?
Spr0ckEt
(Joe Willets)
December 15, 2023, 10:41pm
8
Greetings, I have installed the HACS repo, and went to install the integration for my Archer AX10000 and got the following error message:
Expecting value: line 1 column 1 (char 0)
Any thoughts as to what could have caused this?
awg
December 16, 2023, 1:48am
9
Working for me on Archer AX3000 - thanks for setting this up!
It would be great if this could expose the IoT Wi-Fi network client numbers too (for each of the 2.4 GHz and 5 GHz networks).
Hi, @AlexandrErohin , love your work on this.
Can confirm that the TP-Link Archer AX73 - V1 is working. Very happy with it
Just 2 questions:
is it possible to change the standard scan interval 30 sec. to a smaller size? For
instance 15 sec. after installation?
after setup I want to be able to logout from the router, because the TP-Link AX 73 only allows 1 admin login.
Thanks in advance.
Thank you for the info! What version of you AX3000 V1 or V2 ?
Could you make a screenshot of IoT Network in the router UI - I cannot find it
Thank you for the info about Archer AX73 V1 support!
About questions
Unfortunately, it can only change in setup window . You need to delete integration and configure it again. In the future release it would be added changing the system options
To get updates from the router - the integration on every updates - logs in → gets updates → logs out.
So by default it logs in and logs out every 30 seconds. If you want to log in in UI - you would be logged out from UI when the integration makes its next update.
Okay that’s clear. So I’ll change the settings after a new install.
Thanks for the quick response!
awg
December 19, 2023, 1:29am
15
It is AX3000 V1.
This is what the IoT Network UI looks like:
wow your AX3000 V1 looks like AX3000 V2
Unfortunately, my router doesnt have IoT Network - so I cannot add it to the integration.
It would be great if you could add it to the client GitHub - AlexandrErohin/TP-Link-Archer-C6U: Python package for API access and management for TP-Link Router and then I add to the home assistant component
awg
December 19, 2023, 7:08pm
17
Hmm, the sticker on the bottom says “v1.6”, so I assume that’s V1. It is this model , not this model .
I can try to add it, might take some time.
Could you check your links - it looks like links are the same
