Custom_components directories and files
Do the custom_components directories reside in the correct place under /CONFIG ?
Setup failed for python_script: Integration failed to initialize.
21:57:43 – (ERROR) setup.py
Folder python_scripts not found in configuration folder
21:57:43 – (WARNING) python_script
I get also this error message, but do not understand where the error cause could be. I use this component for the custom calculations i make in multiply.py
"Platform error sensor.custom_calculations - Integration 'custom_calculations' not found."
Init.py:
from . import custom_component
from . import sensor
file custom_component:
import homeassistant.components.sensor
import homeassistant.helpers.config_validation as cv
import multiply
class MyCalculationsSensor(homeassistant.components.sensor.Sensor)
    def __init__(self, hass, name):
        self._name = name
        self._state = None
        self.update()
    def update(self):
        self._state = multiply.calculate_result()
    @property
    def name(self):
        return self._name
    @property
    def state(self):
        return self._state
def register(hass):
    hass.components.sensor.async_register_entity_service(
        'custom_calculations', 'custom_calculations', 'update')
    return True
file sensor.py:
class MyCalculationsSensor(custom_component.MyCalculationsSensor):
        self._name = name
        self._state = None
        self.update()
    def update(self):
    @property
    def name(self):
        return self._name
    @property
    def state(self):
        return self._state
and in configuration.yaml the following sensor:
  - platform: custom_calculations
My initial thoughts was BAD choice of names , is this something you cooked together yourself, or is this “Custom_component” an official-github component ?
