Custom_components not working - can't install them
Hi
I’m confused.
I have Home Assistant running on an Odroid N2. It’s all up to date. I use duckdns. It’s in advanced mode.
I have the Node Red addon running so I can use the Givenergy flow to monitor my solar battery. However the flow tells me I need the node red integration.
I’ve created the custom_components folder using file browser and have loaded the nodered integration files in to a folder called nodered. I’ve also put the Skoda Connect custom component in its own fodler i the hope of using that integration.
When I try to install the integrations, neither NodeRed nor Skoda appear.
I muist be doing something wrong, can someone please help
thanks
