Custom_components not working. Platform not found
Hi, i’m trying to add a custom component to my home assistant, but when checking configuration, I am getting the below error message.
Component not found: climate.heatmiserWIFI.
Home assistant log file shows the below error:
2018-04-08 20:20:01 ERROR (SyncWorker_14) [homeassistant.loader] Unable to find component climate.heatmiserWIFI
Anybody able to help me understand whats causing this?
The custom component is this one.
https://github.com/daveNewcastle/HassIO-config/tree/master/custom_components/climate
and I have followed the instructions and copied it to the /config/custom_components/climate folder and added the configuration as per the readme. Not much else to do.
I am running home assistant in docker on synology.
any suggestions?
thanks
I’m having the same problem with a custom light component, anyone found a soultion for this?
The custom_components folder must be in the HA configuration directory (where all the yaml files reside) if I’m not mistaken.
