Where do I need to copy a custom_components\component folder on a Home Assistant OS instance for it to be recognised?
I have previously been running Home Assistant in Docker on a Synology NAS - Docker on the NAS stopped working so I’m trying a fresh Home Assistant Operating System install on a NUC as per Generic x86-64 - Home Assistant
On the old instance I ran this custom component:
Tried to install for this component by copying to \config\custom_components\amberelectric (the config folder where configuration.yaml is saved) as working in my old setup
Restarted Home Assistant and even the HAOS, then modified configuration.yaml - however when I then try to restart HA I get this:
Failed to call service homeassistant/restart. The system cannot restart because the configuration is not valid: Platform error sensor.amberelectric - Integration ‘amberelectric’ not found.
Do custom_components need to go somewhere else for HAOS?
