I think this error is related, but I can’t tell where it goes.
I am sure it is missing the “key” but I not sure what. Since this was working in the past, it has to be something new. Unfornutally the last time I know it worked was in July and I skipped a lot of versions in between so I am not sure what version notes to go back to.
Here is the error…
Log Details (ERROR)
Sat Feb 23 2019 07:49:55 GMT-0600 (Central Standard Time)
Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/discovery.py", line 161, in async_load_platform
hass, component, hass_config)
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 56, in async_setup_component
return await task # type: ignore
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 124, in _async_setup_component
conf_util.async_process_component_config(hass, config, domain)
File "/usr/local/lib/python3.7/site-packages/homeassistant/config.py", line 719, in async_process_component_config
for p_name, p_config in config_per_platform(config, domain):
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/__init__.py", line 18, in config_per_platform
for config_key in extract_domain_configs(config, domain):
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/__init__.py", line 41, in extract_domain_configs
return [key for key in config.keys() if pattern.match(key)]
AttributeError: 'Config' object has no attribute 'keys'
Here is the code …
For more details about this platform, please refer to the documentation
https://home-assistant.io/components/cover/almond_plus
import logging
import requests
import traceback
import datetime
from homeassistant.components.cover import (
CoverDevice, PLATFORM_SCHEMA, SUPPORT_OPEN, SUPPORT_CLOSE, STATE_OPENING, STATE_CLOSING)
from homeassistant.const import (STATE_UNKNOWN, STATE_CLOSED, STATE_OPEN)
_LOGGER = logging.getLogger(__name__)
DOMAIN = "almond_plus"
DATA_ALMONDPLUS = "ALMONDPLUS"
def setup_platform(hass, config, add_devices, discovery_info=None):
global my_almond_plus
return_value = False
try:
_LOGGER.debug("Started - find me 3")
my_almond_plus = hass.data[DATA_ALMONDPLUS]["almondplus_api"]
covers = []
_LOGGER.debug("looking for devices (cover)")
for almond_key, almond_entity in my_almond_plus.get_device_list().items():
_LOGGER.debug("Device Name (cover) "+almond_entity.name+" type "+almond_entity.type)
if almond_entity.type == "53":
tmp = AlmondPlusCover(almond_entity)
_LOGGER.debug("Device - Str (cover)"+str(tmp))
_LOGGER.debug("Device - (cover)" + tmp.id + ", " + tmp.device_id + ", " + tmp.state + ", " + tmp.name)
covers.append(tmp)
if len(covers) > 0:
add_devices(covers)
hass.data[DATA_ALMONDPLUS]["almondplus_cover_entities"] = covers
return_value = True
except Exception as e:
_LOGGER.error("Error\n"
+ "**************************\n"
+ str(e) + "\n"
+ traceback.format_exc()
_LOGGER.debug("Setup ended with " + str(return_value))
return return_value
# "4":{
# "Data":{
# "ID":"4",
# "Name":"GarageDoorOpener Two Car",
# "FriendlyDeviceType":"GarageDoorOpener",
# "Type":"53",
# "Location":"Default",
# "LastActiveEpoch":"1531243088",
# "Model":"Unknown: type=4744,",
# "Version":"0",
# "Manufacturer":"Linear"
# "DeviceValues":{
# "1":{
# "Name":"BARRIER OPERATOR",
# "Value":"0",
# "Type":"44"
class AlmondPlusCover(CoverDevice):
"""Representation of a Almond+ cover."""
def __init__(self, device):
self._id = None
self._device_id = None
self._name = None
self._state = None
"""Attributes"""
self.friendly_device_type = None
self.type = None
self.location = None
self.last_active_epoch = None
self.model = None
self.value_name = None
self.value_value = None
self.value_type = None
self._state_before_move = None
self._update_properties(device)
def _update_properties(self, device):
self._id = device.id
self._device_id = device.device_id
self._name = DOMAIN+"_"+device.name + '_' + device.id + '_' + device.device_id
self._state = ''
self.set_state(device.value_value)
"""Attributes"""
self.friendly_device_type = device.friendly_device_type
self.type = device.type
self.location = device.location
self.last_active_epoch = device.last_active_epoch
self.model = device.model
self.value_name = device.value_name
self.value_value = device.value_value
self.value_type = device.value_type
@property
def name(self):
"""Return the name of the cover."""
return self._name
@property
def id(self):
"""Get the name of the pin."""
return self._id
@property
def device_id(self):
return self._device_id
@property
def should_poll(self):
return False
@property
def device_state_attributes(self):
"""Return the optional state attributes."""
data = {}
data["id"] = self._id
data["device_id"] = self._device_id
data["friendly_device_type"] = self.friendly_device_type
data["type"] = self.type
data["location"] = self.location
data["last_active_epoch"] = self.last_active_epoch
data["last_active_datetime"] = datetime.datetime.fromtimestamp(int(self.last_active_epoch))
data["model"] = self.model
data["value_name"] = self.value_name
data["value_value"] = self.value_value
data["value_type"] = self.value_type
return data
def update(self, device):
_LOGGER.debug("Switch Update -"+self._id+"-"+self.device_id+"-")
self.schedule_update_ha_state()
def set_state(self, value_value):
_LOGGER.debug("Setting State -"+value_value+"-"+value_value.lower()+"-")
if value_value.lower() == "0":
self._state = STATE_CLOSED
_LOGGER.debug("Setting closed "+self._state)
elif value_value.lower() == "255":
self._state = STATE_OPEN
_LOGGER.debug("Setting open "+self._state)
elif value_value.lower() == "254":
self._state = STATE_OPENING
_LOGGER.debug("Setting opening " + self._state)
elif value_value.lower() == "252":
self._state = STATE_CLOSING
_LOGGER.debug("Setting closing " + self._state)
else:
self._state = 'unknown'
_LOGGER.debug("Setting unknown " + self._state)
_LOGGER.debug("Setting State Finish "+self._state)
@property
def is_opening(self):
"""Return if the cover is opening."""
if self._state in [STATE_UNKNOWN]:
return None
return self._state in [STATE_OPENING]
@property
def is_closing(self):
"""Return if the cover is closing."""
return None
return self._state in [STATE_CLOSING]
@property
def is_closed(self):
"""Return if the cover is closed."""
return None
return self._state in [STATE_CLOSED, STATE_OPENING]
def close_cover(self, **kwargs):
"""Close the cover."""
if self._state not in [STATE_CLOSED, STATE_CLOSING]:
_LOGGER.debug("Close Cover")
self._state_before_move = self._state
my_almond_plus.set_device(self.id, self.device_id, "0")
def open_cover(self, **kwargs):
"""Open the cover."""
if self._state not in [STATE_OPEN, STATE_OPENING]:
_LOGGER.debug("Open Cover")
my_almond_plus.set_device(self.id, self.device_id, "255")
@property
def supported_features(self):
"""Flag supported features."""
return SUPPORT_OPEN | SUPPORT_CLOSE
