Custom Dark Sky Animated Weather Card
thank you.
I still get the card with the content everthing in one side
edited: had a wrong path for css. now it’s centered but missing the icons
Finish step 1 : This is original post with how to and where files located and what file needed.
Step 2: This post custom dark sky animated weather card.
@Sunonline
id done another path mistake. Now all working.
thank you very much for your help.
Nice card. Works great. Thanks.
For some reason it appears to not be working since the 77.2 update - any known issues?
Change the reference in the js code from
hass.config.core.unit_system
to
hass.config.unit_system
Thanks - only found two references in the .js code and no change unfortunately
thanks- sorted… had “v” number in the lovelace file that is now removed. Cheers
Good day, can you tell me which “v”?, which line?
thank you
  • url: /local/custom_ui/dark-sky-weather-card.js?
    type: js
  • url: /local/alarm_control_panel-card.js?v=0.3.2
    type: js
In the ui.lovelace.yaml file at the top under resources. The alarm card is an example of what I removed
thank you. so in the jss i modified this block
const getUnit = function (measure) {
  const lengthUnit = hass.config.unit_system.length;
  switch (measure) {
    case 'air_pressure':
      return lengthUnit === 'km' ? 'hPa' : 'inHg';
    case 'length':
      return lengthUnit;
    case 'precipitation':
      return lengthUnit === 'km' ? 'mm' : 'in';
    default:
      return hass.config.unit_system[measure] || '';
and removed the version in resources.
no luck.
Anything else you did?
That was it for me - removed to references of core from that block of code and the change in the ui.yaml file. Might be a browser version? I am using chrome…
never, mind. My mistake.
I was modifying the js of the wrong card :wink:
apologies.
thank you for your help.
Log Details (ERROR)
Sun Sep 02 2018 11:49:18 GMT+1000 (Australian Eastern Standard Time)
https://my-domain.duckdns.org:30443/local/custom_ui/dark-sky-weather-card.js:17:43 Uncaught TypeError: Cannot read property ‘unit_system’ of undefined
So I had edited the dark-sky-weather-card.js as per your post. What do you mean by you were editing the wrong card???
I also never had the version number in the lovelace yaml file:
- url: /local/custom_ui/dark-sky-weather-card.js
  type: js
You must use a version number in lovelace.yaml. Each time the .js file changes the version number needs to change in lovelace.yaml. That’s how it knows to load the new code. Without a version number change Lovelace is not loading your changes and using the old code…
Also remember to clear your browser cache after making the changes (close any windows with HA open in them first) and then reopen HA
funny it was working… so url: /local/custom_ui/dark-sky-weather-card.js?v=5 ?
yes … assuming 5 is higher than the prior version
well I had no prior version… so I could use anything? 1?
Yep … also it will work without a version … until you change the .js file for the first time. then it wont load the changes until a version is specified
so change the js file to"
      switch (measure) {
        case 'length':
          return lengthUnit;
        default:
Ah ok so I can use 1…
Havent seen this with another one I use…
