EDIT: Mar 03, 2019
Dark Sky Weather Card
The Dark Sky Weather Card provides current and forecasted weather conditions using the Dark Sky platform. You configure the card by passing in sensor entities from the Dark Sky Sensor platform.
The card is very customizable. You can configure many aspects of it’s look and feel as well as which specific content to show by passing in customization flags and defining optional sensors. Content can also be rearranged if desired.
Hovering over a forecast day will display the daily weather summary in a tooltip popup if that option has been enabled.
The complete readme file can be found here. It contains the latest instructions on how to setup the card as well as how to use the various features.
The latest version of the card can be found here.
The GitHub site is here. Please use GitHub issues to request new features as it makes them easier to track.
Original Post:
For reference only.
See above for links to current card and instructions
A couple of folks have asked about using the very nice Custom Animated Weather Card by @arsaboo with Dark Sky. I modified the card based on my needs. - All credit goes to the folks who created the original and those that modified it to get it to where I could hack together something that works for me.
My modified version uses the Dark Sky Sensor Platform as shown below:
sensors.yaml code:
- platform: darksky
api_key: <REDACTED>
forecast:
- 1
- 2
- 3
- 4
- 5
monitored_conditions:
- icon
- summary
- nearest_storm_distance
- nearest_storm_bearing
- humidity
- temperature
- temperature_high
- temperature_low
- apparent_temperature
- apparent_temperature_high
- apparent_temperature_low
- wind_speed
- wind_bearing
- precip_type
- precip_probability
- precip_accumulation
- precip_intensity
- precip_intensity_max
- uv_index
- daily_summary
- pressure
- visibility
update_interval:
minutes: 5
I pass in the sensor entities the card needs. Note the forecast_low_temp entities are staggered back 1. This will use the low temp for the morning of the specific day which matches the way the Dark Sky app shows it.
Note: All the entities listed below are required.
ui-lovelace.yaml code:
- type: custom:dark-sky-weather-card
entity_sun: sun.sun
entity_daily_summary: sensor.dark_sky_daily_summary
entity_current_conditions: sensor.dark_sky_icon
entity_humidity: sensor.dark_sky_humidity
entity_pressure: sensor.dark_sky_pressure
entity_temperature: sensor.dark_sky_temperature
entity_visibility: sensor.dark_sky_visibility
entity_wind_bearing: sensor.dark_sky_wind_bearing
entity_wind_speed: sensor.dark_sky_wind_speed
entity_forecast_high_temp_1: sensor.dark_sky_daytime_high_temperature_1
entity_forecast_high_temp_2: sensor.dark_sky_daytime_high_temperature_2
entity_forecast_high_temp_3: sensor.dark_sky_daytime_high_temperature_3
entity_forecast_high_temp_4: sensor.dark_sky_daytime_high_temperature_4
entity_forecast_high_temp_5: sensor.dark_sky_daytime_high_temperature_5
entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature
entity_forecast_low_temp_2: sensor.dark_sky_overnight_low_temperature_1
entity_forecast_low_temp_3: sensor.dark_sky_overnight_low_temperature_2
entity_forecast_low_temp_4: sensor.dark_sky_overnight_low_temperature_3
entity_forecast_low_temp_5: sensor.dark_sky_overnight_low_temperature_4
entity_forecast_icon_1: sensor.dark_sky_icon_1
entity_forecast_icon_2: sensor.dark_sky_icon_2
entity_forecast_icon_3: sensor.dark_sky_icon_3
entity_forecast_icon_4: sensor.dark_sky_icon_4
entity_forecast_icon_5: sensor.dark_sky_icon_5
I am by no means a JavaScript developer . I make no claim that the way I approached this is the best or even a good way. It works for me and that’s what I set out to do
dark-sky-weather-card.js:
class DarkSkyWeatherCard extends HTMLElement {
set hass(hass) {
if (!this.content) {
const card = document.createElement('ha-card');
const link = document.createElement('link');
link.type = 'text/css';
link.rel = 'stylesheet';
link.href = '/local/custom_ui/dark-sky-weather-card.css';
card.appendChild(link);
this.content = document.createElement('div');
this.content.className = 'card';
card.appendChild(this.content);
this.appendChild(card);
const getUnit = function (measure) {
const lengthUnit = hass.config.core.unit_system.length;
switch (measure) {
case 'air_pressure':
return lengthUnit === 'km' ? 'hPa' : 'inHg';
case 'length':
return lengthUnit;
case 'precipitation':
return lengthUnit === 'km' ? 'mm' : 'in';
default:
return hass.config.core.unit_system[measure] || '';
const transformDayNight = {
"below_horizon": "night",
"above_horizon": "day",
const sunLocation = transformDayNight[hass.states[this.config.entity_sun].state];
const weatherIcons = {
'clear-day': 'day',
'clear-night': 'night',
'rain': 'rainy-5',
'snow': 'snowy-6',
'sleet': 'rainy-6',
'wind': 'cloudy',
'fog': 'cloudy',
'cloudy': 'cloudy',
'partly-cloudy-day': 'cloudy-day-3',
'partly-cloudy-night': 'cloudy-night-3',
'hail': 'rainy-7',
'lightning': 'thunder',
'thunderstorm': 'thunder',
'windy-variant': `cloudy-${sunLocation}-3`,
'exceptional': '!!',
const windDirections = [
'N',
'NNE',
'NE',
'ENE',
'E',
'ESE',
'SE',
'SSE',
'S',
'SSW',
'SW',
'WSW',
'W',
'WNW',
'NW',
'NNW',
'N'
var forecastDate1 = new Date();
forecastDate1.setDate(forecastDate1.getDate()+1);
var forecastDate2 = new Date();
forecastDate2.setDate(forecastDate2.getDate()+2);
var forecastDate3 = new Date();
forecastDate3.setDate(forecastDate3.getDate()+3);
var forecastDate4 = new Date();
forecastDate4.setDate(forecastDate4.getDate()+4);
var forecastDate5 = new Date();
forecastDate5.setDate(forecastDate5.getDate()+5);
const currentConditions = hass.states[this.config.entity_current_conditions].state;
const humidity = hass.states[this.config.entity_humidity].state;
const pressure = Math.round(hass.states[this.config.entity_pressure].state);
const temperature = Math.round(hass.states[this.config.entity_temperature].state);
const visibility = hass.states[this.config.entity_visibility].state;
const windBearing = windDirections[(Math.round((hass.states[this.config.entity_wind_bearing].state / 360) * 16))];
const windSpeed = Math.round(hass.states[this.config.entity_wind_speed].state);
const forecast1 = { date: forecastDate1,
condition: this.config.entity_forecast_icon_1,
temphigh: this.config.entity_forecast_high_temp_1,
templow: this.config.entity_forecast_low_temp_1, };
const forecast2 = { date: forecastDate2,
condition: this.config.entity_forecast_icon_2,
temphigh: this.config.entity_forecast_high_temp_2,
templow: this.config.entity_forecast_low_temp_2, };
const forecast3 = { date: forecastDate3,
condition: this.config.entity_forecast_icon_3,
temphigh: this.config.entity_forecast_high_temp_3,
templow: this.config.entity_forecast_low_temp_3, };
const forecast4 = { date: forecastDate4,
condition: this.config.entity_forecast_icon_4,
temphigh: this.config.entity_forecast_high_temp_4,
templow: this.config.entity_forecast_low_temp_4, };
const forecast5 = { date: forecastDate5,
condition: this.config.entity_forecast_icon_5,
temphigh: this.config.entity_forecast_high_temp_5,
templow: this.config.entity_forecast_low_temp_5, };
const forecast = [forecast1,forecast2,forecast3,forecast4,forecast5];
this.content.innerHTML = `
<span class="icon bigger" style="background: none, url(/local/icons/weather_icons/animated/${weatherIcons[currentConditions]}.svg) no-repeat; background-size: contain;">${currentConditions}</span>
<span class="temp">${temperature}</span><span class="tempc"> ${getUnit('temperature')}</span>
<span>
<ul class="variations right">
<li><span class="ha-icon"><ha-icon icon="mdi:water-percent"></ha-icon></span>${humidity}<span class="unit"> %</span></li>
<li><span class="ha-icon"><ha-icon icon="mdi:gauge"></ha-icon></span>${pressure}<span class="unit"> ${getUnit('air_pressure')}</span></li>
</ul>
<ul class="variations">
<li><span class="ha-icon"><ha-icon icon="mdi:weather-windy"></ha-icon></span>${windBearing} ${windSpeed}<span class="unit"> ${getUnit('length')}/h</span></li>
<li><span class="ha-icon"><ha-icon icon="mdi:weather-fog"></ha-icon></span>${visibility}<span class="unit"> ${getUnit('length')}</span></li>
</ul>
</span>
<div class="forecast clear">
${forecast.map(daily => `
<div class="day">
<span class="dayname">${(daily.date).toString().split(' ')[0]}</span>
<br><i class="icon" style="background: none, url(/local/icons/weather_icons/animated/${weatherIcons[hass.states[daily.condition].state]}.svg) no-repeat; background-size: contain;"></i>
<br><span class="highTemp">${Math.round(hass.states[daily.temphigh].state)}${getUnit('temperature')}</span>
<br><span class="lowTemp">${Math.round(hass.states[daily.templow].state)}${getUnit('temperature')}</span>
</div>`).join('')}
</div>
<br><span class="unit">${hass.states[this.config.entity_daily_summary].state}</span></br>`;
setConfig(config) {
if (!config.entity_current_conditions ||
!config.entity_humidity ||
!config.entity_pressure ||
!config.entity_temperature ||
!config.entity_visibility ||
!config.entity_wind_bearing ||
!config.entity_wind_speed) {
throw new Error('Please define entities');
this.config = config;
// @TODO: This requires more intelligent logic
getCardSize() {
return 3;
customElements.define('dark-sky-weather-card', DarkSkyWeatherCard);
Only made a small change to the css file so only showing the change. changed it’s name to match the card and avoid conflicts with the original as well.
.forecast {
width: 100%;
margin: 0 auto;
height: 10em;
