I get this error in lovelace, I got it working before, I just got move to the dark sky weather card, can someone help
we suffer the same issueā¦ theyāre called forecast in my setup, because Ive named the sensor like that, to distinguish it from the regular sensor.
Funny thing is the components creates these sensors, so simply deleting them from the group leaves āorphanā sensorsā¦
Ill see if I can find the devās [age for this component. Unless you can give me the GitHub, or post an issue referencing this discussion here?
EDIT:
filed the issue, see:
Getting a blank page - and this in the log:
/local/custom_ui/dark-sky-weather-card.js?v=7.1:86:70 TypeError: undefined is not an object (evaluating āthis.hass.states[this.config.entity_sun].stateā)
The card is having an issue resolving entity_humidity (it thinks it is unknown). Based off your ui-lovelace, it looks like you are trying to pass in sensor.bom_humd for that value. Does that state exist? If so, what is the current value of the state in the states debug panel?
Please post your ui-lovelace (storage mode config if using .84 or above) and your darksky platform configuration.
New Error now:
http://192.168.x.x:8123/local/custom_ui/dark-sky-weather-card.js:17:13 TypeError: hass.config.core is undefined
Any idea?
Maybe this will be a mistake Iāve made, but Iām getting this
ā[ā¦]/custom_ui/dark-sky-weather-card.js?v=3:1:8 Uncaught SyntaxError: Unexpected token {ā
I followed the instruction on github step by step. Any idea?
Did you specify the type as module and not js in ui-lovelace
resources:
- url: /local/custom_ui/dark-sky-weather-card.js?v=7.1
type: module
Hi, I have same errorā¦
ui-lovelace.yaml
resource:
type: module
title: Home
- icon: mdi:home-assistant
title: Default view
cards:
- type: custom:dark-sky-weather-card
entity_sun: sun.sun
entity_daily_summary: sensor.dark_sky_daily_summary
entity_current_conditions: sensor.dark_sky_icon
entity_humidity: sensor.dark_sky_humidity
entity_pressure: sensor.dark_sky_pressure
entity_temperature: sensor.dark_sky_temperature
entity_visibility: sensor.dark_sky_visibility
entity_wind_bearing: sensor.dark_sky_wind_bearing
entity_wind_speed: sensor.dark_sky_wind_speed
entity_forecast_high_temp_1: sensor.dark_sky_daytime_high_temperature_1
entity_forecast_high_temp_2: sensor.dark_sky_daytime_high_temperature_2
entity_forecast_high_temp_3: sensor.dark_sky_daytime_high_temperature_3
entity_forecast_high_temp_4: sensor.dark_sky_daytime_high_temperature_4
entity_forecast_high_temp_5: sensor.dark_sky_daytime_high_temperature_5
entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature_0
entity_forecast_low_temp_2: sensor.dark_sky_overnight_low_temperature_1
entity_forecast_low_temp_3: sensor.dark_sky_overnight_low_temperature_2
entity_forecast_low_temp_4: sensor.dark_sky_overnight_low_temperature_3
entity_forecast_low_temp_5: sensor.dark_sky_overnight_low_temperature_4
entity_forecast_icon_1: sensor.dark_sky_icon_1
entity_forecast_icon_2: sensor.dark_sky_icon_2
entity_forecast_icon_3: sensor.dark_sky_icon_3
entity_forecast_icon_4: sensor.dark_sky_icon_4
entity_forecast_icon_5: sensor.dark_sky_icon_5
entity_summary_1: sensor.dark_sky_summary_1
entity_summary_2: sensor.dark_sky_summary_2
entity_summary_3: sensor.dark_sky_summary_3
entity_summary_4: sensor.dark_sky_summary_4
entity_summary_5: sensor.dark_sky_summary_5
locale: en
static_icons: false
sunset: true
tooltips: true
tooltip_bg_color: 'rgb( 75,155,239)'
tooltip_border_color: orange
tooltip_border_width: 3
tooltip_caret_size: 10
tooltip_fg_color: '#fff'
tooltip_left_offset: -5
tooltip_width: 100
dark sky
- platform: darksky
api_key: <Your Dark Sky API Key>
language: cs
forecast:
- 0
- 1
- 2
- 3
- 4
- 5
- 6
- 7
monitored_conditions:
- summary
- precip_probability
- wind_speed
- cloud_cover
- icon
- temperature
- temperature_low
- temperature_high
- apparent_temperature
- daily_summary
- hourly_summary
- humidity
- uv_index
- pressure
- visibility
- nearest_storm_distance
units: ca
Can you please check and let me know, what IĀ“m doing wrong?
Many thanks
That worked. Didnāt noticed that change ā¦ and Iāve checked 5 times
Thank you so much. Love this card.
this is the config, im in yaml mode
ui-lovelace
- type: "custom:dark-sky-weather-card"
entity_sun: sun.sun
locale: en
static_icons: false
sunset: true
tooltips: true
tooltip_width: 100
- type: module
config.yaml
- platform: darksky
api_key: hhjhj
update_interval:
minutes: 10
forecast:
- 0
- 1
- 2
- 3
- 4
- 5
- icon
- summary
- nearest_storm_bearing
- humidity
- temperature
- temperature_high
- temperature_low
- apparent_temperature_high
- apparent_temperature_low
- wind_speed
- wind_bearing
- precip_type
- precip_accumulation
- precip_intensity
- precip_intensity_max
- uv_index
- daily_summary
- pressure
- visibility
Are you using the latest version of the card from github? That particular configuration check and error message was removed a couple versions agoā¦
Glad you got it working !
Hi, IĀ“m sure that IĀ“m using it as I copied it as raw file. Any other idea, why itĀ“s not working?
Iām having problems too, but not just on lovelace. it seems that the darksky platform does not give me the sensors in my home assistant
Just to ensure all the basics have been covered ā¦
- You replaced ā Your Dark Sky API Key ā with your actual API key in the dark sky platform config.
- You restarted HA after setting up the dark sky platform.
- You cleared your browser cache and refreshed the UI.
If all those are true can you post a screen cap of some of the dark-sky sensor states from the states debug panel. I want to make sure they are not showing up as unknownā¦
Post your darksky configuration
- platform: darksky
api_key: my API Darksky
update_interval: '00:30:00'
forecast:
- 1
- 2
- 3
- 4
- 5
language: it
#name: Meteo
- summary
- icon
- precip_type
- precip_intensity
- hourly_summary
- daily_summary
- temperature
- temperature_high
- temperature_low
- dew_point
- wind_speed
- wind_bearing
- cloud_cover
- minutely_summary
- humidity
- pressure
- visibility
- ozone
- uv_index
