I merely asked because your var declaration uses quotes.
but my sensor complies and it works!
cool!
strangely enough it seems to interfere with the cards unit while Lovelace constantly refreshes:
a reload of the page brings it back to the correct state.
pandaym:
Now just one more thing. When I do alt entries, is there any way to set unit class to part of the text? When I just modified your js, I found that setting would make sure the unit was lowered to look nice. Can I do that in my template sensor?
Currently the entire text you provide will use the css style for the slots. Not sure if that can be changed to allow embedded style changes⊠Itâs non trivial in any case.
You mean like this one here
pandaym
(Bendix)
February 18, 2019, 4:07pm
873
Oh ok. Sounds like it is not possible then.
I still do not understand why it cannot just pick up the unit together with the value from the sensor. I assume it would be much preferred to have those always connected, instead of being two individual things? Could it be done with a raw flag for something that just takes whatever the sensor gives, in my case a value and m/s.
Yes it would be if Dark sky was consistent in the way it handles units. Unfortunately its not. It seems to vary widely based on locales and uom settings in the sensor.
In the future, I may have the uom attribute be used as an option. That way if it works correctly for you it could be used and if not it would fall back to the simple lookup⊠I will add it to the list of enhancements.
Hate to tell you this but 0.88.0b3 is breaking this card and a bunch of @thomasloven ones as well. Balloob did a fix for Thomas here https://github.com/thomasloven/lovelace-card-tools/pull/11 I bet itâs likely the same issue?
Changing line 4 to:
var LitElement = LitElement || Object.getPrototypeOf(customElements.get("home-assistant-main"));
Fixes it
Thanks for catching this. I have updated the card to use âhome-assistant-mainâ as the source for the LitElement prototype.
IMPORTANT
HA 0.88 will break the card if you have not updated to the latest version. Thanks to @DavidFW1960 for catching the breaking change in the 0.88 beta.
New version is available here
0.10.2
Updated LitElement source object to âhome-assistant-mainâ as âhui-error-entity-rowâ is being removed in HA 0.88 update.
hiâŠ
i make HA update to 0.88 and update the darksky weather card to the new version ,
but always got error :
dark-sky-weather-card.js?v=7.1:4:39 Uncaught TypeError: Cannot convert undefined or null to object
any idea how to fix it ?
I have a problem to, updated to 0.88 and:
Custom element doesnât exist: dark-sky-weather-card.
firstof9
(firstof9)
February 21, 2019, 2:09pm
880
Update to the 0.10.2 version of the card.
pepeEL
(pepeEL)
February 21, 2019, 7:48pm
881
I also have a problem with Custom Dark Sky on new version Home Assistant 0.88.
I get error. I have a version custom card 0.10.2
firstof9
(firstof9)
February 21, 2019, 8:35pm
882
If you are using Chrome hit F12 then right click the refresh button and click âEmpty Cache and Hard Reloadâ.
pepeEL
(pepeEL)
February 22, 2019, 6:35am
883
Hi. I open windows by F12 but i can not found option about which you talkâŠ
pepeEL
(pepeEL)
February 22, 2019, 6:47am
885
Ok i found and works ok thanksâŠ
ThaNerd
(Turbo Tronix)
February 22, 2019, 9:43pm
886
No matter what I do this card never shows up on my Lovelace. I followed the latest info and used the 0.10.2 version but nothing shows up.
Check entities numbering in card configuration, on my HA card started work after changing
entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature_0
entity_forecast_low_temp_2: sensor.dark_sky_overnight_low_temperature_1
entity_forecast_low_temp_3: sensor.dark_sky_overnight_low_temperature_2
entity_forecast_low_temp_4: sensor.dark_sky_overnight_low_temperature_3
entity_forecast_low_temp_5: sensor.dark_sky_overnight_low_temperature_4
to
entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature_1
entity_forecast_low_temp_2: sensor.dark_sky_overnight_low_temperature_2
entity_forecast_low_temp_3: sensor.dark_sky_overnight_low_temperature_3
entity_forecast_low_temp_4: sensor.dark_sky_overnight_low_temperature_4
entity_forecast_low_temp_5: sensor.dark_sky_overnight_low_temperature_5
Do you have day 0 in the forecast conditions?
If you donât thatâs why you see an error.
ThaNerd
(Turbo Tronix)
February 22, 2019, 11:54pm
889
I have the latest dark-sky-weather-card.js in /config/www/custom_ui
Here is my code:
dark-sky-weather-card.js copied from: https://github.com/iammexx/home-assistant-config/blob/master/ui/darksky/dark-sky-weather-card.js
icons in: /config/www/icons/weather_icons (two folders inside this folder: animated and static)
configuration.yaml:
weather:
- platform: darksky
api_key: !secret darksky
forecast:
- 0
- 1
- 2
- 3
- 4
- 5
monitored_conditions:
- icon
- summary
- nearest_storm_distance
- nearest_storm_bearing
- humidity
- temperature
- temperature_high
- temperature_low
- apparent_temperature
- apparent_temperature_high
- apparent_temperature_low
- wind_speed
- wind_bearing
- precip_type
- precip_probability
- precip_accumulation
- precip_intensity
- precip_intensity_max
- uv_index
- daily_summary
- pressure
- visibility
update_interval:
minutes: 5
ui-lovelace.yaml:
title: Home Control Panel
resources:
- url: /local/custom_ui/tracker-card.js?track=true
type: js
- url: /local/custom_ui/card-tools.js?track=true
type: js
- url: /local/custom_ui/card-modder.js?track=true
type: js
- url: /local/custom_ui/compact-custom-header.js?track=true
type: module
- url: /local/custom_ui/state-switch.js?track=true
type: js
- url: /local/custom_ui/layout-card.js?track=true
type: js
- url: /local/custom_ui/thermostat-card.js?track=true
type: module
- url: /local/custom_ui/ecobee-card.js
type: js
- url: /local/custom_ui/dark-sky-weather-card.js
type: module
- title: Main
icon: mdi:weather-cloudy
cards:
- type: custom:dark-sky-weather-card
entity_current_conditions: sensor.dark_sky_icon
entity_temperature: sensor.dark_sky_temperature
entity_forecast_high_temp_1: sensor.dark_sky_daytime_high_temperature_1
entity_forecast_high_temp_2: sensor.dark_sky_daytime_high_temperature_2
entity_forecast_high_temp_3: sensor.dark_sky_daytime_high_temperature_3
entity_forecast_high_temp_4: sensor.dark_sky_daytime_high_temperature_4
entity_forecast_high_temp_5: sensor.dark_sky_daytime_high_temperature_5
entity_forecast_icon_1: sensor.dark_sky_icon_1
entity_forecast_icon_2: sensor.dark_sky_icon_2
entity_forecast_icon_3: sensor.dark_sky_icon_3
entity_forecast_icon_4: sensor.dark_sky_icon_4
entity_forecast_icon_5: sensor.dark_sky_icon_5
entity_summary_1: sensor.dark_sky_summary_1
entity_summary_2: sensor.dark_sky_summary_2
entity_summary_3: sensor.dark_sky_summary_3
entity_summary_4: sensor.dark_sky_summary_4
entity_summary_5: sensor.dark_sky_summary_5
- type: custom:ecobee-card
entity: climate.my_ecobee3
- type: custom:thermostat-card
title: Guest Room
entity: climate.stelpro_stzw402_electronic_thermostat_heating_1
- !include lovelace/doors.yaml
- !include lovelace/lights.yaml
- !include lovelace/alarm.yaml
- !include lovelace/remote.yaml
- !include lovelace/settings.yaml
- !include lovelace/testing.yaml
I donât see any of these entities under my state viewâŠ
this is the error I get:
