Custom Dark Sky Animated Weather Card
Thanks.
I tried, nothing happens.
Hi @fairchildbrad
here is the dark-sky-weather-card.js
class DarkSkyWeatherCard extends HTMLElement {
  set hass(hass) {
    if (!this.content) {
      const card = document.createElement('ha-card');
      const link = document.createElement('link');
      link.type = 'text/css';
      link.rel = 'stylesheet';
      link.href = '/local/custom_ui/dark-sky-weather-card.css';
      card.appendChild(link);
      this.content = document.createElement('div');
      this.content.className = 'card';
      card.appendChild(this.content);
      this.appendChild(card);
    const getUnit = function (measure) {
      const lengthUnit = hass.config.core.unit_system.length;
      switch (measure) {
        case 'air_pressure':
          return lengthUnit === 'km' ? 'hPa' : 'inHg';
        case 'length':
          return lengthUnit;
        case 'precipitation':
          return lengthUnit === 'km' ? 'mm' : 'in';
        default:
          return hass.config.core.unit_system[measure] || '';
    const transformDayNight = {
      "below_horizon": "night",
      "above_horizon": "day",
    const sunLocation = transformDayNight[hass.states[this.config.entity_sun].state];
    const weatherIcons = {
      'clear-day': 'day',
      'clear-night': 'night',
      'rain': 'rainy-5',
      'snow': 'snowy-6',
      'sleet': 'rainy-6',
      'wind': 'cloudy',
      'fog': 'cloudy',
      'cloudy': 'cloudy',
      'partly-cloudy-day': 'cloudy-day-3',
      'partly-cloudy-night': 'cloudy-night-3',
      'hail': 'rainy-7',
      'lightning': 'thunder',
      'thunderstorm': 'thunder',
      'windy-variant': `cloudy-${sunLocation}-3`,
      'exceptional': '!!',
    const windDirections = [
      'N',
      'NNE',
      'NE',
      'ENE',
      'E',
      'ESE',
      'SE',
      'SSE',
      'S',
      'SSW',
      'SW',
      'WSW',
      'W',
      'WNW',
      'NW',
      'NNW',
      'N'
    var forecastDate1 = new Date();
    forecastDate1.setDate(forecastDate1.getDate()+1);
    var forecastDate2 = new Date();
    forecastDate2.setDate(forecastDate2.getDate()+2);
    var forecastDate3 = new Date();
    forecastDate3.setDate(forecastDate3.getDate()+3);
    var forecastDate4 = new Date();
    forecastDate4.setDate(forecastDate4.getDate()+4);
    var forecastDate5 = new Date();
    forecastDate5.setDate(forecastDate5.getDate()+5);
    const currentConditions = hass.states[this.config.entity_current_conditions].state;
    const humidity = hass.states[this.config.entity_humidity].state;
    const pressure = Math.round(hass.states[this.config.entity_pressure].state);
    const temperature = Math.round(hass.states[this.config.entity_temperature].state);
    const visibility = hass.states[this.config.entity_visibility].state;
    const windBearing = windDirections[(Math.round((hass.states[this.config.entity_wind_bearing].state / 360) * 16))];
    const windSpeed = Math.round(hass.states[this.config.entity_wind_speed].state);
    const forecast1 = { date: forecastDate1,
    				   condition: this.config.entity_forecast_icon_1,
    				   temphigh: this.config.entity_forecast_high_temp_1,
    				   templow:  this.config.entity_forecast_low_temp_1, };
    const forecast2 = { date: forecastDate2,
    				   condition: this.config.entity_forecast_icon_2,
    				   temphigh: this.config.entity_forecast_high_temp_2,
    				   templow:  this.config.entity_forecast_low_temp_2, };
    const forecast3 = { date: forecastDate3,
    				   condition: this.config.entity_forecast_icon_3,
    				   temphigh: this.config.entity_forecast_high_temp_3,
    				   templow:  this.config.entity_forecast_low_temp_3, };
    const forecast4 = { date: forecastDate4,
    				   condition: this.config.entity_forecast_icon_4,
    				   temphigh: this.config.entity_forecast_high_temp_4,
    				   templow:  this.config.entity_forecast_low_temp_4, };
    const forecast5 = { date: forecastDate5,
    				   condition: this.config.entity_forecast_icon_5,
    				   temphigh: this.config.entity_forecast_high_temp_5,
    				   templow:  this.config.entity_forecast_low_temp_5, };
    const forecast = [forecast1,forecast2,forecast3,forecast4,forecast5];
    this.content.innerHTML = `
      <span class="icon bigger" style="background: none, url(/local/icons/weather_icons/animated/${weatherIcons[currentConditions]}.svg) no-repeat; background-size: contain;">${currentConditions}</span>
      <span class="temp">${temperature}</span><span class="tempc"> ${getUnit('temperature')}</span>
      <span>
        <ul class="variations right">
            <li><span class="ha-icon"><ha-icon icon="mdi:water-percent"></ha-icon></span>${humidity}<span class="unit"> %</span></li>
            <li><span class="ha-icon"><ha-icon icon="mdi:gauge"></ha-icon></span>${pressure}<span class="unit"> ${getUnit('air_pressure')}</span></li>
        </ul>
        <ul class="variations">
            <li><span class="ha-icon"><ha-icon icon="mdi:weather-windy"></ha-icon></span>${windBearing} ${windSpeed}<span class="unit"> ${getUnit('length')}/h</span></li>
            <li><span class="ha-icon"><ha-icon icon="mdi:weather-fog"></ha-icon></span>${visibility}<span class="unit"> ${getUnit('length')}</span></li>
        </ul>
      </span>
      <div class="forecast clear">
          ${forecast.map(daily => `
              <div class="day">
                  <span class="dayname">${(daily.date).toString().split(' ')[0]}</span>
                  <br><i class="icon" style="background: none, url(/local/icons/weather_icons/animated/${weatherIcons[hass.states[daily.condition].state]}.svg) no-repeat; background-size: contain;"></i>
                  <br><span class="highTemp">${Math.round(hass.states[daily.temphigh].state)}${getUnit('temperature')}</span>
                  <br><span class="lowTemp">${Math.round(hass.states[daily.templow].state)}${getUnit('temperature')}</span>
              </div>`).join('')}
      </div>
      <br><span class="unit">${hass.states[this.config.entity_daily_summary].state}</span></br>`;
  setConfig(config) {
    if (!config.entity_current_conditions ||
    		!config.entity_humidity ||
    		!config.entity_pressure ||
     		!config.entity_temperature ||
    		!config.entity_visibility ||
    		!config.entity_wind_bearing ||
    		!config.entity_wind_speed) {
      throw new Error('Please define entities');
    this.config = config;
  // @TODO: This requires more intelligent logic
  getCardSize() {
    return 3;
customElements.define('dark-sky-weather-card', DarkSkyWeatherCard);
I was not able to find errors in log, where should I look and what should I look for?
@woody4165
In your dark-sky-weather-card.js file and remove .core from:
to read
hass.config.unit_system.length
(Line 17. Line 26 as well but do not include .length)
This string occurs twice in the same function. There was a breaking change in Home Assistant and the source code for this card has not yet been updated.
Once you have done that you may need to increment the ?v= on your resources line in order for your browser to load the new file.
Thanks @fairchildbrad
It’s working perfectly!!! :ok_hand:
Hi all,
thank you for this topic who helped me to config the card.
I have just a ā€œstrangeā€ issue: I can see the temp but not the degree (C° in my case). Can someone please support me?
Thank you
can you post the code in your dark-sky-weather-card.js file and .css file?
sure:
dark-sky-weather-card.js:
  set hass(hass) {
      const lengthUnit = hass.config.unit_system.length;
      switch (measure) {
        case 'length':
          return lengthUnit;
        default:
          return hass.config.unit_system.length[measure] || '';
      'clear-day': 'day',
      'rain': 'rainy-5',
      'snow': 'snowy-6',
      'sleet': 'rainy-6',
      'wind': 'cloudy',
      'fog': 'cloudy',
      'cloudy': 'cloudy',
      'hail': 'rainy-7',
      'N',
      'NNE',
      'NE',
      'ENE',
      'E',
      'ESE',
      'SE',
      'SSE',
      'S',
      'SSO',
      'SO',
      'OSO',
      'O',
      'ONO',
      'NO',
      'NNO',
      'N'
      <span>
        </ul>
        </ul>
      </span>
              <div class="day">
                  <span class="dayname">${(new Date(daily.date).toLocaleDateString("it-IT", {weekday: 'short'})).toString().split(' ')[0]}</span>
              </div>`).join('')}
      </div>
  setConfig(config) {
  getCardSize() {
    return 3;
dark-sky-weather-card.css:
.clear {
    clear: both;
  .card {
    margin: auto;
    padding-top: 2em;
    padding-bottom: 1em;
    padding-left: 1em;
    padding-right:1em;
    position: relative;
  .ha-icon {
    height: 18px;
    margin-right: 5px;
    color: var(--paper-item-icon-color);
  .temp {
    font-weight: 300;
    font-size: 4em;
    color: var(--primary-text-color);
    position: absolute;
    right: 1em;
  .tempc {
    font-weight: 300;
    font-size: 1.5em;
    vertical-align: super;
    position: absolute;
    right: 1em;
    margin-top: -14px;
    margin-right: 7px;
  .variations {
    display: inline-block;
    font-weight: 300;
    list-style: none;
    margin-left: -2em;
    margin-top: 4.5em;
  .variations.right {
    position: absolute;
    right: 1em;
    margin-left: 0;
    margin-right: 1em;
  .unit {
    font-size: .8em;
  .forecast {
    width: 100%;
    margin: 0 auto;
    height: 10em;
  .day {
    display: block;
    width: 20%;
    float: left;
    text-align: center;
    border-right: .1em solid #d9d9d9;
    line-height: 2;
    box-sizing: border-box;
  .dayname {
    text-transform: uppercase;
  .forecast .day:first-child {
    margin-left: 0;
  .forecast .day:nth-last-child(1) {
    border-right: none;
    margin-right: 0;
  .highTemp {
    font-weight: bold;
  .lowTemp {
    color: var(--secondary-text-color);
  .icon.bigger {
    width: 10em;
    height: 10em;
    margin-top: -4em;
    position: absolute;
    left: 0em;
  .icon {
    width: 50px;
    height: 50px;
    margin-right: 5px;
    vertical-align: middle;
    background-position: center center;
    background-repeat: no-repeat;
    text-indent: -9999px;
  .weather {
    font-weight: 300;
    font-size: 1.5em;
    text-align: left;
    position: absolute;
    top: -0.5em;
    left: 6em;
    word-wrap: break-word;
    width: 30%;
@Jokerigno In your dark-sky-weather-card.js file, remove the .length from the last line of this function. It should read:
  switch (measure) {
    case 'length':
      return lengthUnit;
    default:
      return hass.config.unit_system[measure] || '';
My instructions were not precisely clear earlier.
That’s just a picture-glance card…
Hi! Could you say how did you manage the issue with fuzziness on ios app?
It worked. Thanks!
Thanks for that!
I got all the darksky sensors showing up in HA, but the card in Lovelace is not coming up. Getting the following error in the log after I select the view or refresh the page which is triggering service: Service system_log/write called
/local/custom_ui/dark-sky-weather-card.js?v=4:17:13 TypeError: hass.config.core is undefined
Anyone an idea what might be causing this error?
ignore, was a FF cache issue.
I’ve been using this card for a few months now and it works great. I’ve never had any issue displaying the card however I noticed for awhile now that whenever I go to the lovelace page that displays this card my cpu shoots up to 80% and stays there until I move to another page. It then drops back down to less than 20%. I temporarily removed this card and went back to the page and the cpu stayed below 20% so I know this card is impacting the cpu usage. I tried it on FF also and it didn’t go quite as high but was still near 60%.
Is anyone else seeing this or have an idea why this is happening? I don’t see any errors in the page.
I really like this card and want to continue using it however I would have to make a change if I can’t figure out why the demand on cpu is so high.
I’ve followed tutorial and all work great! Only 2 questions:
  1. How can I translate SUN, MON, TUE, … in italian (Lun, Mar, Mer, …) ? I’ve set ā€œlanguage: itā€ under ā€œ- platform: darkskyā€ but, name of days don’t change.
  2. How can I take old non-lovelace UI function, where when I click on a icon weather, a popup appear with the history of weather?
I was getting load of errors being thrown in the logs with the final being
ā€œdark-sky-weather-card.js?v=9:17:9 TypeError: hass.config.core is undefinedā€
I found this here.
After making the changes to the JS code using find and replace ( find hass.config.core.unit_system replace hass.config.unit_system [all]) it solved my problems and everything is working as designed.
Running 0.82.1
I have a problem with the card.
It only display DIM (Sunday) for every day and I don’t manage to get minTemp:
I justed followed the instructions and didn’t made any change on it.
Hi mtannerauo,
do you use the original js and css? I’m very confused because I’ve tried lot of combinatons from this topic but I allways get the doesn’t exist result.
Hi there,
Does any one have issues after latest update with this card.
I am getting:
local/custom_ui/dark-sky-weather-card.js?v=5:135:85 Uncaught TypeError: Cannot read property 'state' of undefined
I remember I had similar error when I was just adding this card to the HA, but then it resolves itself. I am not sure if this will happen again this time :slight_smile:
The line it’s been complaining about in js file:
