Custom deps deployment addon - what does it do?
I don’t understand what this one is doing. I have graph-your-z-wave-mesh-python-auto-update but that one requires networkx in the venv.
I can achieve this through:
docker container exec your_container_id pip3 install networkx
which results in this log:
Collecting networkx
  Downloading https://files.pythonhosted.org/packages/11/42/f951cc6838a4dff6ce57211c4d7f8444809ccbe2134179950301e5c4c83c/networkx-2.1.zip (1.6MB)
Requirement already satisfied: decorator>=4.1.0 in /usr/lib/python3.6/site-packages (from networkx)
Installing collected packages: networkx
Running setup.py install for networkx: started
Running setup.py install for networkx: finished with status 'done'
Successfully installed networkx-2.1
You are using pip version 9.0.1, however version 10.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
but I thought “Custom deps deployment addon” would to the same? This would be convenient as it is run when HA restarts and installs dependencies.
Add-on config has:
  "pypi": [
    "networkx"
  "apk": []
The log says:
starting version 3.2.4
[Info] Remove old deps
[Info] Install pypi modules into deps
[Info] done
Somehow this doesn’t do what I thought it would do - anyone sees something obviously wrong?
Many thanks,
jhh
Indeed, what even is it :slight_smile:
I was browsing the add-ons and clicked ‘Visit Custom deps deployment page for details.’ but it is a broken link.
yep, broken link. I found this thread trying to find some information on how to set it up. I have a custom component (life360.py) that needs updating, and before I did a manual update, I wanted to see if this addon would be useful to automate that.
Same for me.
I don’t get why it is listed under official add-ons.
Sadly, the best documentation for this is likely the script that actually runs when the addon starts…
https://github.com/home-assistant/hassio-addons/blob/master/custom_deps/run.sh
I am trying to install matplotlib using the addon but no luck. It says it couldn’t find the dependencies FreeType and png. Can anyone help please?
It looks like the custom_deps addon was moved to the “hassio addons development” repository:
https://github.com/home-assistant/hassio-addons-development
Seems like you can install it by adding the repository with the URL above, then installing it like you would any other component through the UI.
anyone work this out?
yah just instaled this dev add on - to load the latest ZHA quirks 0.0.54 for testing… seems to be working
Hi, what should I do, after I started this add-on. I’d like to test latest zha quirks also.
