Custom Element doesn't exist: my-custom-card
I’m trying to create my own custom card, but somehow I can’t get Home assistant to see the card as an actual card and I don’t know what I’m doing wrong.
So I followed the instruction and created a file in the /www folder called ‘my-custom-card.js’ with the following code:
class MyCustomCard extends LovelaceCard {
  setConfig(config) {
    if (!config) {
      throw new Error('Invalid configuration');
    this.config = config;
    this.title = config.title || 'My Custom Card';
    // You can define your card's content and behavior here.
  render() {
    // Render your card's content here using HTML or Lit HTML.
    const card = document.createElement('div');
    card.innerHTML = 'Hello, Custom Card!';
    return card;
customElements.define('my-custom-card', MyCustomCard);
And added the resource in the UI as ‘/local/my-custom-card.js’ (I checked and the Javascript file is accessible through this link)
But if I try to add a new card to my lovelace dashboard it firstly doesn’t show up in the types list. And if I try to add it manualy is says:
Custom element doesn’t exist: my-custom-card
What am I doing wrong and how can I fix this?
Did you ever find a solution? I am having the same problem with a simple custom card I made.
I have this problem often - that should be a clue that I am not an expert on this - but two things I have done to try to fix it when it happens:
  1. Clear the cache in the browser, then do a reload through the UI on the dashboard
  2. Open the web tools in your browser and look at the console when you load it. If you have a javascript error, the result is the same… it does not think you have it.
It drove me mad at first, but the above typically addresses it for me.
Full page reload (Ctrl-F5 on PC) did the trick for me, thanks!
I didn’t need to clear the cache.
