Hello, i’m trying with the old-but-gold method of copying and pasting to fix some bugs/implement some functions in the ELV Max Integration ( eQ-3 MAX! - Home Assistant )
I’ve added some sensors, fixed some bugs, this sort of things, but i’d be glad also to add something “bigger”, but for this i need an hand.
- it would be nice to add also a “home” control, to set all thermostat to the same mode/temperature. The system support this (it’s enough to send a command to the cube itself), so i was thinking about creating a climate object on the cube itself, but i’m stuck at thinking how this should look, since this would have no return information at all. How would you design this?
- Is there a common way in Home Assistant to manage weekly climate programs? I mean both for displaying and for changing. Yes, i’d like to add also this
Thanks a lot
PS: obviously if someone is still a MAX user, i’d be glad to share code and testing/development! i understand this is not the correct season to test heating, but that’s it
