Custom Entities
Ok, I’ve read through countless docs and attempted many things but I’m still new so this is beyond me at the moment. I’m planning on having 3 buttons that control some pool valves but they are not entities. I want to click one button to turn a pool valve which I can do through a Raspberry Pi no problem via py scripts. My problem is that since the buttons are not tied to an entity how do I change the state of the button. I know I can use service calls to scripts to update states but I need an entity to update.
Is there a way to create a generic entity?
An input boolean works the same as a switch, and you can tie an automation, script, scene etc to the on and off function.
Thanks, I was fooling around with the input Boolean but thought there was another way.
I’ll go back to that method.
