Understood. I initially asked here because I thought I would be dealing with a jinja template to determine which theme was currently being used. But the solution you gave me is much easier! Thanks again!
not really sure what you mean, but you can set the direction of the horizontal marquee (which btw is obsolete) like this:
header_text: >-
{% set inside=states('sensor.temperatuur_living')%}
{% set outside=states('sensor.temp_current')%}
{% set temp_color='var(--primary-text-color)'%}
{% set symbol='°C' %}
<div style='display: flex;display: -webkit-flex;'>
<div>Ha Rpi4: </div>
<marquee direction='right'>
<span style='color: {{ temp_color }}'>
Inside temperature: {{ inside }}{{ symbol }},
Outside temperature: {{ outside }}{{ symbol }},
</span>
<span style='color: orange;'>
System alerts: {{states('sensor.marquee_alerts')}}
</span>
Summary - {{states('sensor.dark_sky_summary')}},
Daily - {{states('sensor.dark_sky_daily_summary').split('.')[0]}},
Hourly - {{states('sensor.dark_sky_hourly_summary').split('.')[0]}}.
</span>
</marquee>
see: https://developer.mozilla.org/en-US/docs/Web/HTML/Element/marquee
using an input_boolean from the frontend:
header_text: >-
<marquee direction={% if is_state('input_boolean.ch_horizontal_marquee_right','on') %} 'right' {% else %}'left' {% endif %} >
</span>
</span>
</span>
</marquee>
I have some statues and entities that I want to keep track of in multiple views and I have not found any good solution to this problem. Regular cards takes up to much space and feels bulky in general and I want the solution to work on both mobile and bigger screens.
I managed to do this with split view, footer and the template for the header:
Does any one know if I can get the icons to act like they where a part of a Lovelace instead of just âstupidâ CSS/Template? I am currently using a hack with browser-mod but that isnât really a good long term solution.
Depends on what exactly you want those icons to do. If you just want to change icon/color based on state, thatâs totally doable in a template. If you want it to be an actual entity button, trigger entity changes on click, or something similar then I would keep doing what youâre doing. Thatâs not something Iâll be adding to Custom Header.
If the former is what you are looking for than you can do something like this:
Header will show a green icon of a house when input_boolean.test
is on, otherwise it will be a red icon of a bell.
header_text: >-
<ha-icon icon='{% if is_state("input_boolean.test", "on") %}mdi:home{% else %}mdi:bell{% endif %}'
style='color:{% if is_state("input_boolean.test", "on") %}green{% else %}red{% endif %}'</ha-icon>
If this is already what youâre doing, then sorry for telling you something you already know, but you did not show what you have tried or explained what youâre doing with browser-mod.
And just to fit your situation more, hereâs an example to support multiple icons (again, sorry if Iâm telling you something you have already figured out):
header_text: >-
<div>
<div style='display:inline-block'>
<ha-icon icon='{% if is_state("input_boolean.sleeping", "on") %}mdi:home{% else %}mdi:bell{% endif %}'
style='color:{% if is_state("input_boolean.sleeping", "on") %}green{% else %}red{% endif %}'</ha-icon>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
Custom Header wasnât made with these things in mind, itâs just a happy accident that it works.
Thanks, yeah have most of that figured out but you did it a lot better than I did. Didnât know that the worked this way. The code will suddenly be a lot cleaner!
I am trying to accomplish the button part without the amount of âhacksâ I am doing but that looks to be out of reach as of now, as I suspected.
Thanks for this great feature!
That showing your age bro
haha, yep, old guy hereâŚ
using a modern vertical css marquee, but struggling to get this horizontal HTML Marquee to use the CSS method.
Could you help me out?
header_text: >-
{% if is_state('input_boolean.ch_use_header_text_template','on') %}
{% if is_state('input_select.mode','Developer') %}
<marquee direction={% if is_state('input_boolean.ch_horizontal_marquee_right','on')%} 'right' {% else%}'left' {% endif %} >
<span>
User: {{ user }}, User_id: {{ userID }}, Admin: {{ isAdmin }},
Owner: {{ isOwner }}, Device_id: {{ deviceID }}, View: {{ viewTitle }},
Path: {{ viewPath }}, Index: {{ viewIndex }}, Url: {{ url }},
User agent: {{ userAgent }}
</span>
</marquee>
{% else %}
<marquee direction={% if is_state('input_boolean.ch_horizontal_marquee_right','on')%} 'right' {% else%}'left' {% endif%} >
<span style='color: {{temp_color}}'>
Inside temperature: {{inside}}{{symbol}},
Outside temperature: {{outside}}{{symbol}},
</span>
</span>
</span>
</marquee>
{% endif %}
{% else %}Ha Rpi4
{% endif %}
Ive started to read on this, but it is a bit basicâŚhttps://www.w3docs.com/snippets/css/how-to-have-the-marquee-effect-without-using-the-marquee-tag-with-css-javascript-and-jquery.html#make-the-marquee-effect-with-css-animations-horizontally-and-vertically
Lol that s thinking out side the box nice job
@kr_noob Continuing conversation from your comment here, this is the thread for such things.
If you can do it with a jinja template then you can add it to Custom Header, I am no Jinja expert and I just donât have the time to write Jinja for anyone that requests it. This is why I often mention that this feature (complex html, css, and other fancy templates) is unsupported and isnât really a feature at all. Itâs more of a side effect of how things are rendered in CH.
All that being said, you would need to parse the JSON from the sensor you are using and the template section of the developer tools in HA is a great place to start. It even has an example of JSON parsing in the default template it shows. I can give you a bit of a head start, but making this work in the template that you are using would be up to you.
Go to developer tools >> templates
and paste in the following example to see how to pull just the titles from the JSON in your feedparser sensor.
This will show the first 3 titles pulled from the sensor:
{{ state_attr('sensor.npr', 'entries')[0].title }}
{{ state_attr('sensor.npr', 'entries')[1].title }}
{{ state_attr('sensor.npr', 'entries')[2].title }}
This works perfectly - I was able to put this into the header and flip the headlines vertically.
I had seen the JSON example (I know zilch about JSON) but overlooked it bc I thought the example was all about assigning variable vice extracting - but I see what youâre talking about. Thanks again!
Hi everyone. I am completely noob on this so my appologies if my question is stupid.
I have the following code in the raw editor. However it only display the time in compact mode.
What I should do in order to have the rest info in the header?
custom_header:
button_text:
options: '{{ hours12 }}:{{ minutesLZ }}'
header_text: >-
<style> #flipper {color:#999;} #flip {height:24px;overflow:hidden;} #flip >
div > div {color:#fff;height:24px;margin-bottom:24px;display:inline-block;}
#flip div:first-child {animation: show 10s linear infinite;} @keyframes show
{ 0% {margin-top:-144px;} 5% {margin-top:-96px;} 33% {margin-top:-96px;} 38%
{margin-top:-48px;} 66% {margin-top:-48px;} 76% {margin-top:0px;} 100%
{margin-top:0px;}} #flipper p {position:fixed;color:#999; } </style> <div
id=flipper><div id=flip><div><div>
{{states('sensor.outdoor_temperature')}}</div></div><div><div>
{{states('switch.sonoff_100082f95b')}}</div></div><div><div>
{{states('sensor.dark_sky_precip_probability')}}</div></div><div><div>
compact_mode: true
panel: false
Header text is removed in compact mode, itâs what makes it compact. You might want to try split mode. You can also flip split mode by setting footer mode to true.
It worked! thanks.
may I ask how (if) I could add a stable text for example in the below template
in order to get Outdoor Temperature: 18 and not only 18 as it now.?
header_text: >-
Outdoor Temperature: {{states('sensor.outdoor_temperature')}}</div></div><div><div>
Works amazing. So pumped as this delivers everything I need. One question though - using sensor data in the header / footer causes the marquee to restart every time the data updates, so it rarely makes it all the way through given that I have motion sensors and temp data from several rooms here. Any way to disable updating until itâs all the way through all the frames?
Put Outdoor Temperature or any static text in brackets and quotes, like:
{{"Outdoor Temperature: "}}{{states('sensor.outdoor_temperature')}}
The brackets arenât nessisary for static text as itâs just rendering as HTML.
No. CH needs to update on any change to templates.
You could get creative by making a time/date sensor and then a template sensor that will only update its value based on that sensor. So, for example, the template sensorâs value_template would be the state of the sensor youâre interested in and the entity would be sensor.date
This would make it so that the sensor would only update once a day. You would then make an automation that used the homeassistant.update_entity
service to update the template sensor with whatever interval youâd like.
Havenât tried any of this myself, but it should do what you want.
This is so coolâŚ
I can just copy that and adjust?
Instead of the sensors for weather i would love to have a greeting depending on time
- notifications for ex when machine is on.
Can someone point me how to do this?
I have this already but not sure how to integrate this into this header text
EDIT: ok meanwhile i found it, it rocks ! thx guys
- platform: time_date
display_options:
- time
- date
- date_time
sensors:
greeting:
value_template: >
{% set state = states('sensor.time') %}
{% if '00:00' <= state < '06:00' %}
Goeienacht !
{% elif '06:00' <= state < '12:00' %}
Goeiemorgen !
{% elif '12:00' <= state < '18:00' %}
Goeiemiddag !
{% else %}
Goeieavond !
{% endif %}
