The fix for this is mentioned above in Steven_Rollason’s post. This is due to the icon changes in 0.110 and requires the icon to be wrapped in a div.
hi, how do I disable access to custom header for a user and also be able to set a default theme for that user?
Thanks to you
Custom Header doesn’t select themes, you would set that in the user’s settings found at the very bottom of the HA sidebar.
To disable access to CH settings you would use an user exception with a config that hides CH settings.
thanks a lot for your help the problem is that i don’t have access to the sidebar anymore to change my theme…
conditions:
user: garage
config:
default_tab: '1'
disable_sidebar: true
show_tabs: '1'
menu_hide: true
hide_tabs: '0,2,3,4,5,6,7,8,9,10'
hide_ch_settings: true
hide_help: true
To temporarily restore the default header, sidebar, etc check the first two important notes found here. Or just change the sidebar setting, select the theme, and disable sidebar again.
Oh, right, well, thank you very much for all your help and hard work. Good job.
You can simplify your config by removing hide tabs. show_tabs is an alternative to hide_tabs, there is no need for both. Show tabs will show only the tabs listed and hide tabs will hide the ones listed. Also, disable_sidebar automatically hides the menu button so you can remove that as well:
conditions:
user: garage
config:
default_tab: '1'
show_tabs: '1'
hide_help: true
Okay, great. Thanks a lot. I’ll do that right now.
Hey Steven,
I took your code and for some reason I see a ‘n’ after the weather icon.
Have you come across that?
I tried removing things here and there, but I can only remove it by removing the whole icon div tag
I don’t see that on mine. I can only think that there is a stray character between the and the - what does your config look like (it looks slighty different to mine, as I don’t have the date)?
Got this… And I even tried removing the ‘dayNameShort’ because of the Scandinavian character ‘ø’, but that didn’t change a thing.
custom_header:
background: 'rgba(150, 150, 150);'
button_text:
options: >-
{{ hours24 }}:{{ minutesLZ }} - {{ dayNameShort }}. {{ dayNum }}. {{ monthNameShort }} - <div
style='display: inline-block; height:32px; width:32px;
vertical-align:middle;'><ha-icon icon='mdi:weather-{%- if
is_state('weather.dark_sky', 'partlycloudy') -%}partly-cloudy {%- elif
is_state('weather.dark_sky', 'clear-night') -%}night {%- else
-%}{{states('weather.dark_sky')}}{%- endif -%}'></ha-icon></div>
{{states.weather.dark_sky.attributes.temperature }}°
remove the extra indent before the last line:
button_text:
options: >-
monthNameShort }} - <div style='display: inline-block; height:32px;
width:32px; vertical-align:middle;'><ha-icon icon='mdi:weather-{%- if
Oh my…! How easy
Than you guys!
With latest release these errors show up pretty often in the log. There are at least 100+ same messages around that timeframe. Few occasions HA wouldn’t load (with big error message in red color) and HA would reload only if I select ‘Reload resources’. How do I narrow down this issue?
HA 0.110.1
CH: 1.4.6
2020-05-24 18:41:43 ERROR (MainThread) [frontend.js.latest.202005191] http://192.168.86.226:8123/hacsfiles/custom-header/custom-header.js:596:26328 Uncaught TypeError: Cannot read property 'querySelector' of undefined
Sure. This time I will try to capture screenshot.
Screenshot isn’t really necessary, but info like: your config, browser, and anything else in the list from that link that you think might be helpful. Submitting issues to Github helps me keep track of them and will automatically ask you for the required info I need to try to replicate and troubleshoot the issue.
I have the same problem as Yoinkz
which indent should be removed?
The one that he had on the last line of the code he posted. The code from my comment has the indent removed from his code.
If your’s is different, post it here and I could try to see your issue.
I got to work right.
Thanks for help
