I’m trying to add support for a tmp75 to my esphome install. I’m tripping over myself somewhat. Does anyone have any examples?
I’ve looked at
I²C Bus — ESPHome (How i2c works on esphome)
http://www.esp32learning.com/code/esp32-and-tmp175-digital-temperature-sensor-example.php (How the tmp75 works on the i2c bus)
Custom I²C Device — ESPHome (How custom i2c works)
Custom Sensor Component — ESPHome (how custom sensors work)
This is what I have so far. If compiles and loads, but the board becomes immediately non responsive. Any advice would be appreciated.
#include "esphome.h"
byte TempHi; // Variable hold data high byte
byte TempLo; // Variable hold data low byte
boolean P_N; // Bit flag for Positive and Negative
unsigned int Decimal; // Variable hold decimal value
void Cal_Temp();
class TMP75 : public PollingComponent, public Sensor {
public:
// constructor
TMP75() : PollingComponent(15000) {}
void setup() override {
// This will be called by App.setup()
Wire.begin();
delay(1000);
void update() override {
// This will be called every "update_interval" milliseconds.
const int I2C_address = 0x4f; // I2C write address
delay(100);
Wire.beginTransmission(I2C_address);
Wire.write(1); // Setup configuration register
Wire.write(0x60); // 12-bit
Wire.endTransmission();
Wire.write(0); // Setup Pointer Register to 0
while (1)
delay(1000);
// Read temperature value
Wire.requestFrom(I2C_address, 2);
while(Wire.available()) // Checkf for data from slave
TempHi = Wire.read(); // Read temperature high byte
TempLo = Wire.read(); // Read temperature low byte
Cal_Temp ();
// Display temperature
publish_state(Decimal);
void Cal_Temp()
if (TempHi&0x80) // If bit7 of the TempHi is HIGH then the temperature is negative
P_N = 0;
else // Else the temperature is positive
P_N = 1;
TempHi = TempHi & 0x7F; // Remove sign
TempLo = TempLo & 0xF0; // Filter out last nibble
TempLo = TempLo >> 4; // Shift right 4 times
Decimal = TempLo;
Decimal = Decimal * 625; // Each bit = 0.0625 degree C
- platform: custom
lambda: |-
auto diningtemp = new TMP75();
App.register_component(diningtemp);
return {diningtemp};
sensors:
name: "Dining Room Temperature"
