Custom Integration: Alfa by Sinapsi data integration
HA Custom Integration: Alfa by Sinapsi energy monitoring device
GitHub ReleaseBuyMeCoffeeCommunity Forum
GitHub ActivityProject Maintenancehacs
This project is not endorsed by, directly affiliated with, maintained, authorized, or sponsored by Sinapsi
Introduction
HA Custom Component to integrate data from Sinapsi Alfa device.
Tested on my Alfa to monitor the power/energy consumption and photovoltaic power/energy production directly from the energy provider’s OpenMeter 2.0.
Alfa is a great product, it provides official measurements, and it provides local API to get the data (for now it’s through ModBus).
So finally here we are with the first official version of the HA custom integration for Alfa devices. :slight_smile:
Features
  • Installation/Configuration through Config Flow UI
  • Sensor entities for all data provided by the device
  • Configuration options: Name, hostname, tcp port, polling period
  • Reconfigure options (except device name) also at runtime: no restart needed.
Installation through HACS
This integration is available in HACS official repository. Click this button to open HA directly on the integration page so you can easily install it:
Quick installation link
  1. Either click the button above, or navigate to HACS in Home Assistant and:
    • ‘Explore & Download Repositories’
    • Search for ‘Alfa by Sinapsi’
    • Download
  2. Restart Home Assistant
  3. Go to Settings > Devices and Services > Add Integration
  4. Search for and select ‘Alfa by Sinapsi’ (if the integration is not found, do a hard-refresh (ctrl+F5) in the browser)
  5. Proceed with the configuration
Manual Installation
Download the source code archive from the release page. Unpack the archive and copy the contents of custom_components folder to your home-assistant config/custom_components folder. Restart Home Assistant, and then the integration can be added and configured through the native integration setup UI. If you don’t see it in the native integrations list, press ctrl-F5 to refresh the browser while you’re on that page and retry.
Configuration
Configuration is done via config flow right after adding the integration. After the first configuration you can change parameters (except device name) at runtime through the integration page configuration, without the need to restart HA.
  • custom name: custom name for the device, that will be used as prefix for sensors created by the component
  • ip/hostname: IP/hostname of the inverter - this is used as unique_id, if you change it and reinstall you will lose historical data, that’s why I advice to use hostname, so you can change IP without losing historical data
  • tcp port: TCP port of the device. tcp/502 is the only known working port, but I preferred to leave it configurable
  • polling period: frequency, in seconds, to read the registers and update the sensors
4a0b3168-4f4a-489f-90ac-eaff6edab6e2
Sensor view
7664a9a6-a5ed-4b9e-ab52-d863e2c1e523
Coffee
If you like this integration, I’ll gladly accept some quality coffee, but please don’t feel obliged. :slight_smile:
BuyMeCoffee
Hi, I have another alpha installed on a three-phase meter with 80kw power. From alpha they had to modify the reading values ​​per app by multiplying by 25 so as to have the real values, but I notice that these multiplied values ​​on the alpha app are not read on your integration which still reads the non-multiplied values. Would it be possible to multiply by 25? It would be nice to include in the configuration both the alpha IP and another field whether or not to multiply by 25 which would be the K coefficient. K=25 is also talked about on the internet. Thank you
Ask Sinapsi to publish these values in modbus. Probaly the register map changed and they added these specific values in other addresses. I have to stick to the default register map.
Meanwhile, if it’s just a *25 problem, you can create template sensors and multiply the alpha sensors by 25.
Hi, when trying to add the integration I get an “unknown error”. Alfa is running and reachable.
Any pointers on where to look/how to proceed?
Thanks in advance.
I would need the debug log to know what’s happening, but I’m 99% sure it’s DNS: try using the FQDN hostname and also IP address instead of the simple hostname. Remember it’s HA having to resolve the hostname, the test on another system is not valid, you should test from the HA shell. Furthermore you used PING, try to use host to solve it “host alfa.domain”.
Hi Alex, you were spot on, using FQDN solved the issue (I don’t want to use the IP address in case it changes as per your suggestion).
Thanks a lot.
Always remember the #1 rule of troubleshooting: “it’s ALWAYS dns”
Hi, I installed the integration without problems, congratulations for the excellent work, I wanted to know if it was possible to use the sensor.alfa_power_consumed in the energy card, I tried but it doesn’t see that sensor while in the device the sensor exists and correctly collects the data
The energy integration only accepts energy sensors, not power sensors. You need to choose the energy sensors provided by the integration (production, consumption, return to grid).
Hi, I integrated Alfa without any problem.
However, I often get “entity not available” in home assistant.
Alfa is connected by checking through its app. Reloading the integration solves the problem temporarily. Do you know any fixes for the issue?
Enable debug on the integration until the problem comes up again. Then open an issue on the repo and attach the debug log so we can see what happened.
I just installed the alfa device on my home and put the adviced configuration in configuration.yaml as i was not aware of the alfa integration. Now, if i install the integration, will i have the sensors created by yaml mode migrated to the UI Flow or do i miss all the sensors and forced to create a new entry through GUI?
You have to remove the manual configuration of the modbus registers. Simply use the custo component.
Ok, but in this way i loose all previous data or not?
The Alfa gets the energy counters from your main meters, so it won’t start from 0.
Ok, i installed alfa, but i loose the previous daily values.
One question, having a mono-oraria cost do i need to put into the energy dashboard source only the sensor.alfa_energia_prelevata or do i need to put all the 3 peaks (F1,F2,F3) ?
The energy integration needs the total energy consumption (or production) sensor. F1/F2/F3 sensors are useful if you need to keep track of when you consume energy, they’re not relevant for the energy integration.
I think these sensors are not working as expected.
I created 3 mushroom entity cards to monitor the consumes of the 3 tariffs and i got this:
Those values don’t reflect the values i can see in the alfatech app as at the moment i got the screenshot, the values in the app are:
F1 3.032kWh
F2 0,345 kWh
F3 1,729 kWh
Why that huge difference?
What is the total consumption, 7,33kWh (integration) or 6kWh (from alfa app)?
The values of the sensors come from the Alfa, through modbus. There’s no manipulation.
Check the timings…I don’t know the alfa app how frequently receives data.
You can also use a tool like qmodmaster to query the Alfa via modbus and check for yourself those 3 values.
6kWh I really don’t know from where 7,33kWh comes up!
How to check with qmodmaster?
It connects in tcp but how to read those values?
