Hello everyone,
I’m working on a new integration, I’m strungling to find a good logic to re-auth to the API having only an API key. Client is towards Google and Firestore.
Here is my current way of doing.
I’ve a routine that way for token expiration and then re-trigger a login. Problem is
self.handlers.append((pool_id, handler))
where at each re-login the handlers will grow. I can solve that, but is there not a better way with home assistant helpers or others to manage a re-login following a token expiration ? I went over the doc, and only came up with the below. thanks for the guidance !
for now, I can just limit my handlers with
max_size = 10
self.handlers = self.handlers[-max_size:]
here is the current code
@classmethod
async def create(cls, aiohttp_session, username, password):
instance = cls(aiohttp_session, username, password)
await instance.signin()
asyncio.create_task(instance.start_token_refresh_routine())
return instance
async def start_token_refresh_routine(self):
while True:
try:
await self.ensure_active_token()
await asyncio.sleep(self.calculate_sleep_duration())
except Exception as e:
_LOGGER.error(f"Error maintaining token: {str(e)}")
break
def calculate_sleep_duration(self):
time_to_expiry = (self.expiry - datetime.datetime.now()).total_seconds()
return max(time_to_expiry - 300, 10)
async def get_token_and_expiry(self):
"""Fetch token and expiry using Google API."""
url = f"{GOOGLE_IDENTITY_REST_API}:signInWithPassword?key={API_KEY}"
headers = {"Content-Type": "application/json; charset=UTF-8"}
data = json.dumps({
"email": self.username,
"password": self.password,
"returnSecureToken": True
resp = await self.aiohttp_session.post(url, headers=headers, data=data)
if resp.status == 400:
raise UnauthorizedException("Failed to authenticate.")
self.tokens = await resp.json()
self.expiry = datetime.datetime.now() + datetime.timedelta(seconds=int(self.tokens["expiresIn"]))
self.credentials = Credentials(token=self.tokens['idToken'])
self.client = Client(project="hayward-europe", credentials=self.credentials)
if hasattr(self, 'handlers') and self.handlers:
for pool_id, handler in self.handlers:
await self.subscribe(pool_id, handler)
async def ensure_active_token(self):
"""Ensure that the token is still valid, and refresh it if necessary."""
_LOGGER.debug(f"Token check, {datetime.datetime.now()} {self.expiry}...")
if datetime.datetime.now() >= (self.expiry - datetime.timedelta(minutes=5)):
_LOGGER.info("Token expired, refreshing...")
await self.get_token_and_expiry()
async def signin(self):
"""Sign in and set the tokens and expiry."""
async def subscribe(self, pool_id, handler) -> None:
doc_ref = self.client.collection("pools").document(pool_id)
def on_snapshot(doc_snapshot, changes, read_time):
"""Handles document snapshots."""
try:
for change in changes:
_LOGGER.debug(f"Received change {change.type} in firestore")
for doc in doc_snapshot:
try:
handler(doc)
except Exception as handler_error:
_LOGGER.error(f"Error executing handler: {handler_error}")
_LOGGER.error(f"Error in on_snapshot: {e}")
doc_ref.on_snapshot(on_snapshot)
